(sorry for the lengthy post, but hopefully it has all the info needed broken down easily to read)
I'm in the process of deciding which software to use for my Back-up workflow configuration. However, I've hit another item I need to consider on which type of back-ups to perform.
Without reading the above thread, here is my intended usage/configuration summary:
- Perform scheduled periodic Windows/C drive image backups to the NAS [will likely use Macrium Reflect to perform this task.]
- Perform scheduled periodic back-ups of my Data drive and files to the NAS
- I want to protect my back-ups from ransomware
- Perform separate backups from the NAS to an external HDD [daily end of day? But this means the HDD needs to always be connected?]
- I will intend on rotating the external HDD backups offsite possibly weekly
- No plans to perform cloud back-up. In the future ideally buy another NAS and store offsite and perform NAS-NAS over internet with HBS
I do intend on taking an image back-up of my C/Windows drive so I can perform a restore without having to reinstall and reconfigure everything.
However for my data files (which sit on a separate drive), I'm now at a point where I need to decide if I want to perform an image based back-up (.bak or .mrbak compressed file) or a file based back-up (equivalent of Copy+Paste in file explorer).
I have done some research on this and I can't really find a conclusive answer (I appreciate it depends on each personal use-case) but I'm hoping to get some views/thoughts on this.
The 2 software options I have identified are:
- NetBak replicator [FILE BACKUP]
- Macrium Reflect (Home edition) [currently using trial version to access and test the File & Folder backup option] [IMAGE BACKUP]
File Backup
Pros
- Access the data without needing to install 3rd party software to restore
- Can perform simple Copy/Paste to select the file you want to restore/recover
- Cannot perform versioning, will only have the 1 copy of the file you have copied across
Pros
- Compressed file (smaller size?)
- Can perform versioning
- Ransomware protection [Macrium has Image Guardian?]
- proprietary compressed file used (.bak or .mrbak compressed file)
- need 3rd party software to access the contents of the back-up
- what if image becomes corrupted or the software is not maintained in the future
Initial questions
- 1. Is there a best practice when it comes to deciding on which one to use? How does the usage determine which one to use?
- 2. Is there an issue to using both methods? Or is that overkill? I imagine space will be the biggest issue here
