Hello: I have issue with qnap authenticate connection with Google drive.
Your solution should resolve this issue but I don't have a good background with computer networking... can you guide how to "disable ssl enforcement" as per the suggested solution "It seems that if you force SSL connections (HTTPS) then Hybrid Backup Sync won't be able to authenticate cloud accounts: so disable ssl enforcements"
Thank you so much
Hybrid backup: unable to authorize accounts for cloud sync
- OneCD
Re: Hybrid backup: unable to authorize accounts for cloud sync
* split into new topic from viewtopic.php?f=15&t=148338 *
