I have old TS-410 NAS (HBS 1). I would like to make it working as backup server. I've setup it to start automatically on scheduled time.
Every time it starts RTRR server never works properly:
Enable Real-time Remote Replication Server: The server is not running properly!
It happens every time server starts. The only fix is to Apply button on web interface.
Is it the command line to start server RTRR manually outside web interface? So I would be able to restart it automatically from script?
Start/Restart RTRR server command line.
Re: Start/Restart RTRR server command line.
Instead of trying to find workarounds for an unhealthy system I would try to reinstall it and make it work as intended. I have an old NAS running HBS 1 as backup server and that never fail to enable the RTRR server on boot.
Hello msmolka,
I have exactly the same problem! "The server is not running properly" every time I try to, and I need to restart it manaully. Have you found any solution?
Thank you in advance and best regards,
Luis
Luis
