HBS3 v17.0.0512 Smart Versioning
Backup, Restore, Netbak Replicator, Cloud Storage Services
Fuzzy John
Getting the hang of things
Post by Fuzzy John »
I have seen this topic brought up a few times but either I did not understand the replies or the replies were for older versions of HBS.
Recently I had to retire my Windows Home Server 2011 with its wonderful backup system so I switched to backing up the NAS folders to a USB 3 enclosure connected to my TS-451+ NAS.
I setup HBS3 with a backup job to be run daily at 7:00 AM. I also set Smart Versioning to 0 hours, 7 days, 8 weeks and 6 months.
Now that I have over a week of backups I checked a Restore job and I see that I can only select from the last 7 days of backups. I expected to also see a weekly backup in the selection list but I do not see one.
Do I have to create Weekly and Monthly schedules in addition to the Daily schedule in my Backup Job?
Do I have to create separate Backup jobs for the Weekly and Monthly?
I am attaching a screenshot that shows the folder structure of the backup drive in FileStation 5.
Thanks!
TS-451+ with 8 GB RAM and 4 IronWolf 2TB (RAID-5).
User of Windows Home Server since early 2008. RIP May 4th, 2021. :cry:
P3R
Re: HBS3 v17.0.0512 Smart Versioning
Post by P3R »
Fuzzy John wrote: Sun May 23, 2021 1:30 am I setup HBS3 with a backup job to be run daily at 7:00 AM. I also set Smart Versioning to 0 hours, 7 days, 8 weeks and 6 months.
Your one week old backup is the same as the 7 day old backup so no need to save it separately as a weekly backup. After two weeks you will see a weekly backup as well. Or if you prefer, you could lower the the days to 6, to see the one week old backup as a weekly backup instead.
At least that's how I understand and have used Smart versioned backups for years.
No.
No.
Fuzzy John
Thank you for clarifying this. When I go to create a Restore job I now see a backup several days before the group of daily backups. I suppose that is the first retained weekly backup.
I wish there was an option to hide the days without backups.
Return to “Backup & Restore”
