I have a working TS-421 with 4 non-NAS 2TB drives of which 3 have failed/replaced over the past 3+ years. QN AP support have suggested replacing the 4 drives.
I have purchased 4 new Iron Wolf NAS 2TB drives and I want to re-create the current QTS environment in the simplest way.
I have 2 on-site backups on external hard drives created/maintained with HBS, and a Cloud backup as well using iDrive.
My configuration is RAID 10. My QTS is 4.3.3 1624.
My question is; can I power down, pull & replace the 4 drives, power up with the same settings (??) and then do a full restore from the external backup?
Or must I redo my configuration because QTS will not retain the existing setup. Or perhaps I can restore the settings from a backup?
I'm not a novice systems user so I can follow instructions. (:> Just looking for advice from experienced users.
4 new drives; can I just power down, add drives ...
Re: 4 new drives; can I just power down, add drives ...
no everything is on the drives, you pull them and all is gone
just insert new drives and setup your NAS from scratch
Thank you! Sort of figured that was the case.
New setup, coming soon.
Morden2004
