hi all,
Pls help. First of all , please know that I am not technical at all and I may even have done things wrongly all along, but here is my situation which I really hope someone can help.
I have a NAS TS 251A, with 2 Hardrives. Recently I got errors saying Disk 2 is over 50 degrees hot and etc etc, I was to replace it soon, finally yesterday it really failed.
So today i remove it and replaced it with an older hard drive, hoping it will autosync to it so that at least I will have another copy until I get a new drive.
But it kept saying error on volume / pool and will not backup/sync. So I removed disk 2 and reboot the NAD, but now one of my storage pool is MISSING.
So my question is , how can I restore that storage pool back out , should I shut the NAS down now etc ? thank you
all my kids and parents photos are in there ! pls pls help asap
Missing Storage Pool, urgent help
Re: Missing Storage Pool, urgent help
You discovered the hard way why you need external backups at all times.
What was the disk configuration ? RAID1,RAID0, Pooled Single Disks, Spanning JBOD ?
If anything else other than RAID1, you array is bust with a single swapped drive.
external backup as in to backup again with another hard drive ?
it was set as RAID1, so am I hopeful ?
A RAID is not a Backup .. so would done a first backup and NOT another one
login to the NAS via SSH and do
and post back the results
md_checker
am embarrassed now and sad.
how to login NAS via SSH, let me search too
is this it ? sorry, i think is one volume/lun missing instead.
/usr/bin/md_checker: line 20: /tmp/RaidUUID: Permission denied
/usr/bin/md_checker: line 21: /tmp/mdinfo: Permission denied
/usr/bin/md_checker: line 22: /tmp/mdinfo_u: Permission denied
/usr/bin/md_checker: line 25: /mnt/HDA_ROOT/md_backup_2021-06-24_01.25.29: Permission denied
Scanning system...
/usr/bin/md_checker: line 31: /tmp/md_stat: Permission denied
/usr/bin/md_checker: line 35: /tmp/md_uuid: Permission denied
/usr/bin/md_checker: line 40: /tmp/md_online: Permission denied
/usr/bin/md_checker: line 43: /tmp/disks: Permission denied
/usr/bin/md_checker: line 64: /tmp/md_dump: Permission denied
RAID metadata found!
UUID: fb3f4425:430c5b3f:43aa4460:365a9705
Level: raid1
Devices: 2
Chunk Size: -
md Version: 1.0
Creation Time: Apr 8 08:41:09 2018
Status: ONLINE (md1) [U_]
Enclosure | Port | Block Dev Name | # | Status | Last Update Time | Events | Array State
/usr/bin/md_checker: line 141: /tmp/mdinfo_u: Permission denied
NAS_HOST 1 /dev/sda3 0 Active Jun 24 00:18:21 2021 1568638 A.
---------------------------------- 1 Missing -------------------------------------------
Scanning system...
Level: raid1
Devices: 2
Chunk Size: -
md Version: 1.0
are you using the admin account on your NAS to login via SSH? .. with that many permission issues you probably are not .. correct ?
no, I am the only admin user, the other user was disable by my friend
tell your friend to reenable the regular admin user..and run it again
