NAS : TS-451
Firmware : 4.5.4.1723
I've been using External 6TB WD Disks for some time to Backup my NAS using a USB 3.0 Caddy.
I have two disks which I rotate regularly but this weekend both Backups Failed!
Hybrid Backup Sync Job Status [Hybrid Backup Sync] Failed to complete Sync job: "Multimedia NAS Backup A". Folder pairs are invalid or inaccessible. Error code: -50
Not sure where to start resolving this issue but very concerned that I have no recent Backups!!!
And I don't find HBS 3 Hybrid Backup Sync to be very intuitive!
HBS 3 Hybrid Backup Sync - Failed to complete Sync job
Re: HBS 3 Hybrid Backup Sync - Failed to complete Sync job
Moomer , I have the same problem with a similar configuration but the 3 Tb disks .. My solution at the moment is to run the backups by hand by disabling the Automatic Backup option ... this way it works, I am waiting for a resolution Ultimately, the problem appears from the last two firmware updates.
NAS : TS-453U
I've been using External 3TB Maxtor Disks for some time to Backup my NAS using a USB 3.0 Caddy.
I hope they find a quick solution to the problem
NAS : TS-453U
Hi PC_NACS - looks like we both have the same problem.
I have logged a Support Call with QNAP and will keep you posted on any progress.
In the meantime I've edited my Sync Jobs from 'Auto-backup' to 'No schedule' and kicked off the first one manually - so far so good!
Did you ever find a solution to this? I'm currently having the same problem with 2 of my Sync Jobs. I even tried turning off the sync schedule and manually syncing but it's still 'Failing to complete Sync Job'.
As a guess, since it seems to be multimedia related, I'd try disabling the multimedia services. Then try the backup in case it was locking files or directories.
