Hello everyone,
my Qnap 109 has been inactive in years.
- After re-entering the NAS it into my network, I did update the firmware (first mistake: never touch a running system, I know) to 3.3.3. (1003T).
- I then couldn't access it through Qnap QFinder anymore. So after hours of attempting to establish connection through the client, decided to reset the Qnap (next mistake).
- Now, after testing several different older Qnap QFinder versions, I finally have the option to reinitialize the system - which I do not want to do, as I suspect to have important files still stored on my hard drive.
Several other QFinder versions hat the option to connect directly via SSH. This didn't work. Current QFinder 5.0.2 (Windows) at least gives me the reinitialization setup wizard...
I have tried to establish connection through putty+SSH - unfortunately it refuses connection too ("Network error: Connection refused").
My main goal is to recover all my data.
Anyone has any idea what I can do?
I have tried to follow some of mentioned steps here: https://www.cyrius.com/debian/orion/qna ... /recovery/ but have to admit I don't really understand all of it (and am failing with SSH connection anyway).
Qnap 109 Recovery
Re: Qnap 109 Recovery
The easiest to recover the data is probably to put the disk in a USB-connected dock/enclosure and attach it to a working Qnap. If the disk is still okay you should find all your files in one of the partitions presented. If you don't have a Qnap then any Linux system should be able to read the disk as well.
Hey again,
thank for your input! I could try this (I have another empty drive I could use to initialize) - however, do you expect the USB connected drive to automatically transfer the files if I connect it to the front USB port? Or would I need to take any specific action?
You will have to copy the things you want from the disk manually.
So, I could initialize the QNAP through a different HDD, hoocked the old one to a USB-dock and connected this to both the front and back USB ports:
- The front port doesn't seem to recognize the USB device.
- When connected to either of the ports in the back, the webinterface crashes and sends me back to the main menu (from "External Device/USB Disk in the "Administration" Area). Are there any alternative ways?
As I said in my first post here: "...any Linux system should be able to read the disk as well.".
Installed Linux, unfortunately it didn't detect the HDD :/
hdd might be busted then..does it spin up or make any noise?
It does spin up, doesn't make any unusual noise though. Tricky, I see...
The drive should be recognized by any garden variety linux..if not ..it might be time to talk to a data recovery company
