I have a Qnap ts-251A which I have been using for a few years now.
However, the most I have been able to get out of it in terms of transfer speeds when doing a backup (using Macrium Reflect) is about 110 Mb/s. This via a USB quick access cable. I've tried two 1gb ethernet connections with link aggregation, as well as separately trying to connect using a QNA-UC5G1T (which turned out to be incompatible with my NAS).
The problem is a full backup of my machine now takes about 2 hours - which I would really like to reduce. Backup drives are 2 4TB HDDs.
I'm wondering if I went to a 10GB solution (another NAS model), but stayed with the HHDs (ie didn't buy SSDs) then realistically what would a realistic transfer speed for my backups be?
(My PC already has a 10 GB ethernet port).
realistic expections
Re: realistic expections
Quick access port is just a virtual 1GbE adapter .. so no wonder.
Depending on the hard-drive moidels used and the RAID level (1,0,SJBOD,(pooled)single), you should get more than 1GbE speeds on sequential transfers on a different model(supporting 2.5-10GbE) .. yes
Thanks, I figured I would get greater speeds - but just how much greater is my question.
Hard-drive models and RAID level were still not disclosed
It would likely be configured as RAID 5; I'm currently using RAID 0 with two drives - but would likely move to RAID 5 with 4 drives in an upgraded machine.
The drives are WD Black 4TB (I don't have the exact model numbers)
WD black are not NAS drives ... WD RED (Plus, Pro) would be
4TB WD Red Plus have a sequential speed of around 140MB\s .. I'd say in a RAID5 you'd get 200-250MB\s of sequential speeds
cool thanks
- Toxic17
How are you going to manage raid5 with a 2 disk bay NAS?
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
I guessed that would go with the "updated other nas model" capable of 10GbE, mentioned in the firts post
