Dear all,
I am using 2 NAS devices - 1st for for productive use and 2nd as off-site backup via HBS3 (RTRR).
The off-site connection is stored as remote NAS on productive one which I consider risky in case of a ransomware attack (proper ransomware developer should leverage the connection and make sure to infect the connected device as well).
Is somebody using a similar scenario? Any mitigations recommended?
HBS security
- Don
Re: HBS security
How are the two sites connected?
Re: HBS security
"Live" or scheduled backups will always be susceptible to an attack vector such as a typical ransomware attack.
Just follow best practices and have a succession of staged backups and / or manual and offline ones in the mix.
As a simple form of "hardening" I incorporated a system wide scan for the common "Readme" file names (as well as *.7z files as I use the .zip even for 7zip files) as an alert mechanism as well as a test in my automated backup scripts to reduce the risk of overwriting a good back with a ransomware encrypted backup.
How far *you* go is of course dependant on how valuable your data is to you. A lot of my files are things I store for convenience and can easily be replaced from other sources, or simply not recovered so essentially have no backup. Other files are extremely important, copied to multiple automated, manual and cloud locations and locked in high security fire-proof safes off-site. The majority fall between these 2 categories.
- Don
Re: HBS security
Are you using a VPN?
Re: HBS security
Thanks for sharing considerations on this.
Just as an example of my thought - if I setup a virtual machine and run my backup tool there instead of using stock HBS3, it allows too many possible scenarios (basically infinity but let's just consider linux VM + trivial rsync script) for ransomware programmer to target my setup and collect credentials allowing compromise offsite instance backup. Ofc primary NAS can be burned/encrypted and rsync would populate this, but e.g. if it is enhanced with snapshots, this could work, huh?
p.s. I hope I am not just a troubled user trying to achieve enterprise class solution using consumer product .
