Watch folder for Torrents?
Hello all,
I would like to be able to place a Torrent file in a folder and have Download Station see that file and start performing the download.
I saw a thread that suggested I SSH into the QNAP and then use the following command: "ln -sf /share/CACHEDEV1_DATA/.torrent /share/CACHEDEV1_DATA/Download/Torrent"
The command did move my Torrent folder but Download Station didn't seem to be watching the folder or if it did, it would not start a download of a file I manually placed in that folder.
Download Station would download files that we dragged into the program...but a manual copy to the folder did nothing.
Has anyone had any success with something like this ?
Thanks in anticipation of any assistance
Cheers,
Chris
Cheers,
Chris
- pwilson
Re: Watch folder for Torrents?
Please access your NAS via SSH. Login as "admin" and run:
Please cut&paste the output of this command back to this message thread.
/sbin/getcfg BTDownload "Torrent Folder"
Patrick M. Wilson
Victoria, BC Canada
- pwilson
Put your Torrent data files there, or install QGet on your other devices.chrisrizzuto wrote:/share/CACHEDEV1_DATA/.torrent
This should work for you until you upgrade to QTS 4.2.0.
Patrick M. Wilson
Victoria, BC Canada
Hmmmm, so that's the problem
I am using QTS 4.2.0 !!
Did they change something?
- pwilson
Switch to Transmission. It still works under QTS 4.2.0.chrisrizzuto wrote:Hmmmm, so that's the problem
Patrick M. Wilson
Victoria, BC Canada
But, I just trained my wife how to use Download Station. Do you know what it is like have to retrain someone who hates computers.
Can I use them simultaneously?
And just out of curiosity, why is QTS 4.2 a problem? Is it just because it is still considered BETA?
- pwilson
Don't ask me. Ask QNAP. Yes you can use Transmission and Download Station simultaneously. I seldom use Download Station here.chrisrizzuto wrote:But, I just trained my wife how to use Download Station. Do you know what it is like have to retrain someone who hates computers.
Patrick M. Wilson
Victoria, BC Canada
The beauty of Download Station is the simplicity of the search for people who don't get the torrent thing. I will use both and setup Transmission to watch my folder while she uses the Search Engine built-in to Download Station.
Thanks very much for your help....I never thought to use both Engines and that solves everything for me !
- pwilson
I can't really help with that part. I use "Google" for finding torrents here. When I click on a "torrent" found via Google it opens in my "Remote Transmission GUI" installed on my PC's, or on "Remote Transmission" on my cellphone/tablet.
I also have a Transmission client add-on within Kodi on the NAS.
Patrick M. Wilson
Victoria, BC Canada
- schumaku
QNAP Download Station does not support a torrent watch folder.
Considering the trend does go away from distributing torrent files towards magnet links I can't see any importance.
- forkless
It does serve purpose as a blackhole enabled client for various automation utilities (Eg. Sickbeard/Rage/Couchpotato et al.) as there are no integration plugins for them.
Any ideas how to get it work again?
I would also be keen to see this feature working again. Its a pain having to go into download station and adding the file seperately
Plus i dont think i can handle the pain of setting up transmission after struggling with sonarr, sickrage, nzbget and sabnzbd
p.s. i am sorry to hear the news about patrick, he was the all time #1 guru that helped me several times with my QNAP
