Fail to update RSS feeds (0x6013)
I'am having this error: "Fail to update RSS feeds (0x6013)" on adding RSS in Download Station V4.2.0
QNAP firmware is 4.2.0 Build 20151023
RSS added before 4.2.0 upgrade (4.1.x version) are working, but now I cannot add new ones.
This was fixed on: http://forum.qnap.com/viewtopic.php?f=1 ... lit=0x6013 in beta and https://www.qnap.com/qts/4.2-release-note/v1/ in stable version.
Anyone can help to fix this?
Re: Fail to update RSS feeds (0x6013)
Same problem here. Downloads not starting from rss feed. Fix needed!!
Just hit that exact problem. Some RSS feeds work, some don't (with that error code). When checked with wget, the RSS URL is correct and the response a valid RSS stream.
Running 4.2.0 Build 20151118 on a TS-453 Pro.
- Toxic17
if you have not already done so, please raise a ticket with QNAP, so they can be notified of the issue.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
Folks,
I've just figured out what the problem is. Download Station doesn't manage redirection (HTTP 301, for instance) properly.
The workaround is to open the RSS URL with wget or curl, and get the final URL where the request is being redirected.
Best,
Alvaro
PS: Simon, the bug ID is #MIL-825-31699
Best,
Alvaro
This problem would appear to have reared its head again. Running 4.2.1 on TS251+ - Worked perfectly up until today!
Yes, because i've tried to use it today for first time and i've got that error.
If you have a correct content in the rss field it will works as expected (without above error code)
Check the following content in your rss (example):
<item>
<title>Kundo.Age.of.the.Rampant.2014.BDrip.Custom.HUN.x264-DenZo [Film (HUN SD)]</title>
<link>https://link/index.phpkey=09e</link>
<description>Kundo.Age.of.the.Rampant.2014.BDrip.Custom.HUN.x264-DenZo</description>
<comments>some comments</comments>
<category>Films from internet</category>
<pubDate>Wed, 19 Oct 2016 19:58:00 +0200</pubDate>
<source url="https://fake.com/rss_dl.php/id=2/key=09 ... ad</source>
</item>
<item>
</item>
where do you add the rss feed?
I'm having the same problem. Is there no solution?
I found that I got the error only why my feed was empty. Provided the RSS feed comprised at least one item, no error was elicited.
