Download station not moving files
Post your questions about BT download, FTP download, HTTP download, or QGet download software here.
kirifet
Post by kirifet »
I know this has been asked a fantamillion times, but I am having troubles with Download station not moving files to the chosen folder after a completed download (not seeding, rather in finished status). So basically I see this:
But the file remains in the temp folder and can only be moved manually.
Anybody experienced something similar?
I'm using QTS 4.3.2.0050 on a TS-131P with Download Station 5.0.22
kirifet
Re: Download station not moving files
Post by kirifet »
Pretty please?
kirifet
Post by kirifet »
OK, OK, I give up!
CylonCenturion
Post by CylonCenturion »
kirifet wrote:OK, OK, I give up!
Use qtransmission instead.
Far better.
JarnoVanDerLinden
Post by JarnoVanDerLinden »
You have to "Stop" the download after it has finished. That moves it to the chosen folder. Then you can "Remove" it from Download Station.
onesolo
Post by onesolo »
I'm also having this problem on latest Download station on v5.0.64 with BT downloads !!
I never experience this before!! I always get finished downloads moved to the "final" directory after I stop from seeding the files!! Now, I don't!!
Does anyone is having this also??
Qnap TS-212P with 2x2TB HDDs (RAID 1)
Return to “Download Station and QGet”
