Download station new version just wiped my db!!!
I just entered my Qnap, and then I got a notification that there was a new update to DS, v5.0.60
The minute I updated DS, I receive a new notification, a Warning, from DS that my database was rebuild due corruption. I got that notification too fast. So I did not understand what happened at that moment. When I entered DS, I then realized what really happened. I got a wipe of my downloads list!!! Nothing is listed on DS !!! This is unacceptable!!! I had some downloads that were not started and were very important!!!
The warning was "[DownloaStation] rebuild corrupted db"
Way to go Qnap!!! Clap Clap!!!
Qnap TS-212P with 2x2TB HDDs (RAID 1)
Re: Download station new version just wiped my db!!!
You should use qtransmission. Way better that DS.onesolo wrote:I just entered my Qnap, and then I got a notification that there was a new update to DS, v5.0.60
Same here! Bravo QNAP! Was very pleased with my cheap but convenient NAS... until now.
@CylonCenturion: Been looking for another download manager since I got my NAS but hesitated because I didn't want to start over. Where do I find Qtransmission? In the app center?
UNIX-loving newly certified Windows technician. GEEK and proud of it.
Hardware:
NAS: QNAP TS-212P with QTS 4.3.3 (for now, planning on replacing it with Debian)
Laptops: 1. HP Pavilion 17-f285nf Core i7, 6GB RAM, 480 GB SSD + 2TB HDD, Windows 10 x64, Ubuntu 17.04 amd64.
2. Apple MacBook Air 2015 Core i5, 8 GB RAM, DIY 500GB SSD, macOS 10.12.5, Windows 10 x64.
Desktop: Lenovo ThinkCentre M58e Core2Duo, 4GB RAM, macOS 10.12.5, Windows 10 x64, Ubuntu 17.04 amd64.
Hardware:
Same problem!
- Baldie
Same here.
I updated and it ran for an evening and now I logged in and got "[DownloadStation] rebuild corrupted db."
Not a nice update!
Not a nice update!
Same problem here. After reinstallation, the problem remains.
Qnap TVS-472XT 32GB | NIC QXG-10G2SF-CX4 | 3 HDD Seagate 6TB | 2 SSD NVMe Samsung 970 Evo 1TB | Drive QDA-A2MAR | 2 SSD Samsung 860 Evo 500GB
@ all the guys above...
contact qnap, by submitting a ticket.
from the qnapclub: https://www.forum-nas.fr/viewtopic.php?t=2148moisemust wrote:Same here! Bravo QNAP! Was very pleased with my cheap but convenient NAS... until now.
Way better than the crappy DS , provided by qnap.
- Don
Did anyone that encountered this problem bother to open a ticket with QNAP to report it or just posted a rant?
Same thing happened to me, I uninstalled the new build (v5.0.60) and then reinstalled the old one (v5.0.48). Afterwards I had to reboot the NAS, everything is working again now.
Here are the download links to the old build (v5.0.48).
TS-531P
http://download.qnap.com/QPKG/DownloadS ... arm_al.zip
TS-NASARM
TAS-X68,TS-531P,TS-X28,TS-X31,TS-X31P2,TS-X31U,TS-X31X,TS-X31XU,TS-X35,TS-X41
http://download.qnap.com/QPKG/DownloadS ... arm_kw.zip
TS-NASX86
http://download.qnap.com/QPKG/DownloadS ... 22_x86.zip
TS-X28
TS-X31
http://download.qnap.com/QPKG/X31/Downl ... arm_ms.zip
TS-X31U
TS-X41
TAS-X68
TS-X31X
TS-X31XU
TS-X35
TS-X31P2
TS-531P
TS-NASARM
TS-NASX86
TS-X28
TS-X31
TS-X31U
TS-X41
TAS-X68
TS-X31X
TS-X31XU
TS-X35
TS-X31P2
Hmm, after what happened, I made two downloads. What happens if I install that previous version? I don't think I will get my previous download list, right ?!jrb wrote:Same thing happened to me, I uninstalled the new build (v5.0.60) and then reinstalled the old one (v5.0.48). Afterwards I had to reboot the NAS, everything is working again now.
TS-531P
TS-NASARM
TS-NASX86
TS-X28
TS-X31
TS-X31U
TS-X41
TAS-X68
TS-X31X
TS-X31XU
TS-X35
TS-X31P2
Folks, just encountered the same issue, and managed to resolve it by SSHing into the NAS and doing:
This just reset the Download Station and I can now log in and it seems to be mostly behaving itself. The only remaining issue is that it fails to start any downloads when using the BT search function. The same downloads start and run fine if I paste the Magnet link in myself.
/share/MD0_DATA/.qpkg/DSv3/etc/init.d/dsd.sh reset
- Qsoft
Thanks jrb for that list - which one do I use for my TS-221?
As onesolo asked - do we get the uncorrupted download list back again?
Dr Paul A Daniels - Director, Qsoft Limited
Marvell ARM (TS-NASARM) is this one
Not sure about whether the list is restored as I wasn't seeding at the time.
x21 is marvel Kirkwood (also x19)
x31 is Coretx A9 (some by Annapurna Labs)
Normally their QPKG's are different
