Hello, After the last update of the firmware, everytime I start the NAs, the download station does not work. If I stop it and then start it again, then it starts working fine. But the problem is that I have scheduled and turn off in the night and turn on in the morning, so every morning the service will be unavailable.
Any solution for this?...
Best regards.
Download Station Problem
Re: Download Station Problem
Before it did work as expected?DrJ76 wrote:Hello, After the last update of the firmware, everytime I start the NAs, the download station does not work. If I stop it and then start it again, then it starts working fine. But the problem is that I have scheduled and turn off in the night and turn on in the morning, so every morning the service will be unavailable.
Best regards.
Of course it did
Enviado desde mi GT-I9505 mediante Tapatalk
Any idea about this?... I have just tried again a few minutes ago and still the same, it is so weird.... I try to access the download station web and it says it is offline. I go to app center, stop download station, start it again, and now the web of download station works perfrect, but everytime I shutdown the NAs, when It starts, again the same situation...
Best regards.
Best regards.
I have tried this night to let DVBLink, an app to record video programs using a TDT USB, stopped. And this morning the download station was working, but to be sure, I restarted the NAs again, with DVBLionk still stopped, and download station did not start, grrrrr... So I tried to uninstall and reinstall download station from the app center, and still the same.... It is so strange....
DVBLink has been there from almost the beginning and everything was working fine, grrrr...
Best regards.
Best regards.
Thу ooooold problem still not fixed
viewtopic.php?t=115108
my solution is
1. Delete DS
2. Install DS again
3. profit
my solution is
1. Delete DS
2. Install DS again
3. profit
I have already done this, thank you
More strange things.... I am able to use download station if I stgop it and restart it again, but now the downloads are not moved to download folder when they finish, they stay in the temporary folder, when usually they were moved to download folder......
Can anybody help me with this?, I have seen the topic aradan gave me, but I don´t see any clear solution there...
Best regards...
Best regards...
Well, the spanish support team tells me that this is a known error and will be fixed in the new version of Download Station, but they don´t know the date of it, grrrr....
Well, at least I am able to stop DS and start it again from the web or the phone and the services works this way, until I restart the NAS.....
Best regards.
Best regards.
Well, it seems that with the new firmware and with the new version of download station the problem has been solved....
Best regards.
Best regards.
I had the same problem, now it downloads in the latest release.
However, not its stuck at the status "creating" after it reaches 100%. Files are not visible in file station
A-one else with this issue?!?
