Download Station is currently offline. New firmware 4.3.3.0299
Hello everyone.
I have a Qnap TS212. Last night I sadly decided to install the new firmware 4.3.3.0299.
When QS 5.0.64 restarts from the message "Download Station is currently offline.To use Download Station, please contact the administrator to enable this service on management center."
I would say that I had happened other times and always after updating the firmware and every time I solved it with the recommended procedure:
1) Stop the service
2) Uninstall DS
3) Reinstall DS
Or interrupting and rebooting or uninstalling DS and reinstalling.
This time none of the methods work.
I'm not sure, but the problem is when I update the firmware, while the QS has the torrent list to download.
Reading around is who would recommend switching to Transmission, but I'm fine with QS, especially since I tried his IOS and Android app.
Some solution, someone has the same problem, some suggestion.
Thank you always and greetings.
1) Stop the service
2) Uninstall DS
3) Reinstall DS
Re: Download Station is currently offline. New firmware 4.3.3.0299
Same here... Seems this issue has been around and not yet solve, anyone can help? Has anyone open ticket to QNAP? Thx
I opened the ticket.
- Toxic17
Similar issue to this:
viewtopic.php?t=115108
the search feature does work. why not try what one user had done...
it might work????I just fixed the issue...
After the upgrade to v4.2.0 the app privileges where changed and didn't apply to my second account anymore...reapplied the privileges and reinstalled the app...
the app now shows on my desktop and is active..
strange that the app permission where changed after upgrade..
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
I had read the post.
I have only one account, that of administrator, to which I can not change the privileges. If that is not the case, please explain how to do it.
Thank you
Thank you
I had the same issue, I had to open the UDP ports on the firewall (the same already opened with TCP).
I checked, but before the upgrade the firmware everything worked.
In the past on my router I opened the doors TCP.
I opened a ticket. The support say me:
"I had upload this issue to QNAP bug tracking system and wish the next release of Download Station 5.0.67".
So I wait.
So I wait.
I have the same issue, Download Station 5.0.64 is stuck in a downloading state and does not progress this was working fine until recently (most likely with the upgrade of QNAP version 4.3.3.0299)
Would be nice if QNAP address this as i have wasted a lot of time before i came across this thread.
Any update on this issue is appreciated
Yes, me too.troymcloure wrote:I checked, but before the upgrade the firmware everything worked.
So I wait.
But now.. open the UDP ports too... and it works. (In my case, I opened ports from 7500 to 7519 TCP and UDP, check your Download Station settings to see what ports are you using (under BT tab))
I'm now using qBittorrent on QNAP (not on the QNAP store) more info on this thread:
viewtopic.php?f=320&t=126484
So far so good....
So far so good....
I would also like to try qBittorrent.ymangera wrote:I'm now using qBittorrent on QNAP (not on the QNAP store) more info on this thread:
So far so good....
My Nas is TS212.The nas should have a Arm processor, but "x41 Version : http://www.qoolbox.fr/QBittorrent_3.3.1 ... 1.qpkg.zip" does not work.
I have tried installing the other versions, but no version is installed.
Do you have any suggestions?
Thank
- Trexx
Unfortunately with that old of a nas model with limited resources, the "solution" more and more will be to "get a new NAS".troymcloure wrote: I would also like to try qBittorrent.
Thank
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I solve ALL.
New version 5.069 is PERFECT.
Thank QNAP
Thank QNAP
Perfect no, but better than previous version.troymcloure wrote:I solve ALL.
Thank QNAP
some addons for torrents has been removed or changed to be working again.
Glad i see a fix on extratorrent and demonoid addon.
TS-453A
