I would like to change the default path for transmission to a folder called "download" in volume 2.
below is the file path I used
/CACHEDEV2_DATA/Download
When I tried to download, transmission appeared to work well for a while but struggled to save to the folder.
I guess the file path I used is wrong, can someone please help?
Default download folder for transmission
Re: Default download folder for transmission
pretty sure you can specify the path in the transmission settings
- TPLINK
i believe the actual path is /share/CACHEDEV2_DATA/Download
TS-2888X-W2133-64G 10Tb WD-Red Qsubsonic, Storage, backup
Acer Aspire 16Gb 8th gen. I7 Windows 10 Home 64Bits
1Tb free Stack
1Tb free Stack
I tried this path:
it seems to have downloaded the video but for some reason, any video download via this path is not playable on PC, i.e. cant be access via the mapped drive.
I can see the file but I can't play it, but it is playable when I logged into the NAS drive and play it file station.
I tried this path:
