FileZilla or other FTP Client for QNAP NAS?
Hey Everyone,
I'm still pretty new to QNAP. Is FileZilla available for the latest QNAP QTS or if not, another similar FTP Client? I saw FileZilla available at QNAP Club. However, after purchasing and installing it, I couldn't get it to work. Then I found out that it appears to only work with a specific model QNAP NAS?
Any help would be greatly appreciated.
Thank you!
BJ
Thank you!
BJ
- Moogle Stiltzkin
Re: FileZilla or other FTP Client for QNAP NAS?
i've used filezilla and quite happy with it.
winscp is also another app i use. i can even access putty from it as for ssh console access (have to enable ssh in qts)
https://www.slant.co/versus/5954/5955/~ ... _vs_winscp
https://www.reddit.com/r/sysadmin/comme ... r_and_why/
If the app comes bundled with malware, you could try using ninite which usually removes all the junkware
https://ninite.com/
PS: i use the apps from my desktop and laptop.
i find winscp especially useful when i need to browse deep into the qnap root directories, which i can't seem to do from windows 10 explorer.
https://ninite.com/
NAS
Network
Resources
Network
Resources
Thank you!! Where can I download FileZilla for QNAP QTS?Moogle Stiltzkin wrote: ↑Mon Dec 31, 2018 5:18 pm i've used filezilla and quite happy with it.
https://ninite.com/
Thx.
BJ
- Moogle Stiltzkin
u want to install a qpkg in qnap?
ooo i thought you meant to run from a desktop/laptop to access the qnap from :X (this is how i use these apps normally)
https://ninite.com
hm... well there is this?
https://www.qnapclub.eu/en/qpkg/552
you can access the filezilla from the qnap hdstation (either use the remote access option, or to connect a hdmi between qnap and monitor + mouse +keyboard and access it that way)
alternatively i know it's possible to simply run a VM windows 10, then install whatever app you need on the qnap.
or use container station (docker)
By the way what qnap model are you using
https://ninite.com
https://hub.docker.com/r/jlesage/filezilla/This is a Docker container for FileZilla.
The GUI of the application is accessed through a modern web browser (no installation or configuration needed on client side) or via any VNC client.
NAS
Network
Resources
Network
Resources
Thank you Moogle! I have a TVS-473. I purchased Filezilla from the QNAP Club, but I am having trouble getting it to actually run.Moogle Stiltzkin wrote: ↑Mon Dec 31, 2018 8:02 pm u want to install a qpkg in qnap?
https://ninite.com
or use container station (docker)https://hub.docker.com/r/jlesage/filezilla/This is a Docker container for FileZilla.
It appeared to have installed correctly and the Service does start, However I don't see where I can actually launch it LOL.
BJ
it's an hd station app..you need to connect keyboard,mouse and monitor to the qnap to use it
- OneCD
As this is becoming rather involved, I’ve got to ask: what is it you’re trying to do? Why do you want FileZilla running on the NAS?
@OneCD,
I want the ability to connect to several of my remote servers and download files directly onto the NAS. I was thinking about using 'rsync' or some other form of file transfer method. However, I like the level of control from an FTP Client like Filezilla, so that I can connect via (S)FTPS.
BJ
BJ
- OneCD
Have you investigated the remote mount feature in File Station?
@OneCD,
I have not. Thank you! I haven't been able to dive-in to my NAS yet, but this will be fun.
Thanks again!
BJ
Thanks again!
BJ
On opkg software list(qnapclub EntWare repo), there are lftp, ncftp tool you can use.
lftp, ncftp also linux command most common FTP client tools.
Model: TS-532x Firmware: QTS-4.5.1.1465
QTS (SSD):
Data (HDD): [RAID-1] 2 x 10TB WD; mount 2T NTFS
VMs (SSD):
Ext. (HDD):
CPU: ARM-64 arch(AnnapurnaLabs Alpine AL324 64-bit ARM Cortex-A57 quad-core 1.7GHz processor)
RAM: Gloway 16G DDR4-2400
GPU:
UPS:
QTS (SSD):
VMs (SSD):
Ext. (HDD):
GPU:
UPS:
