Hi @ all
I recently updated my QNAP TS-221-6TB with firmware version 4.3.3.0789. Since the update download station does not work anymore, it says. Of course download station is installed. I know that this had happened to other users in the past.
I'm not sure if I would delete download station and re-install would the data, torrents be deleted.
Your feedback will be much appreciated
Andy
Download Station does not work after firmware update 4.3.3.0789
Re: Download Station does not work after firmware update 4.3.3.0789
After another issue I finally had to uninstall and reinstall it twice. Problem solved.
