Radarr
Radarr
Hi used to have a synology diskstation.I am now try to setup radarr on my qnap it keeps looking for the disk station how do I stop it .Thanks
Re: Radarr
What QNAP nAS model and firmware+build ?
where are you installing it from ?
qnap club store ?
https://www.qnapclub.eu/en/qpkg/396
qnap club store ?
Re: Radarr
Ya I've installed it but I'm trying to setup the torrent client but just says failed to connect to diskstation which is my old synology
Re: Radarr
doubt a fresh qnap install would know anything about your old Syno setup , did you use some backed up config files or similar ?
Re: Radarr
No just the same pc that's all i removed the old synology ip from router and it's still the same
Re: Radarr
where does the PC come into play ? besides to access the web frontend of radarr on your qnap ?
Re: Radarr
That's all I use it for
Re: Radarr
It's the same if I use the laptop
Re: Radarr
Think I'll just get rid of the qnap rubbish lol
Re: Radarr
just installed radarr for testing and setup was easy
I needed
QMono
Radarr
Qtransmission (or any other compatible download source)
sign up for a datasource (I tried free https://fastnzb.com/)
done..(added some public domain movies for demo)
I needed
QMono
Radarr
Re: Radarr
It probably is my problem trying to connect to my old synology nas I've removed ip from router but still doing the same
Re: Radarr
no sure where the problem lies .. connecting to the interface from your PC's ? .. just use the new NASname or NAS IP
http://NASIP:7878
http://NASNAME:7878
http://NASIP:7878
http://NASNAME:7878
Re: Radarr
Where I've tried in name in ip and in port still the same
Re: Radarr
same IP or NASNAME with QTS interface port works ?
can you post a screenshot of your browser error ?
