Download station 5 BT search not returning results
Post your questions about BT download, FTP download, HTTP download, or QGet download software here.
Locked
eversonl
Post by eversonl »
Download station was working fine just before the latest FW upgrade to me TS-451
Download station v 5.7.0.173
I can force a download and seed existing torrents
The BT search agreement is ticked (both) Like I say this was working fine
torrent searches on laptops work just fine.
I have uninstalled and re0installed multiple times via application centre and via qpkg download
I have also manually removed the /.pkg/DSv3 folder (re-created on subsequent install)
Still no joy. I've logged a ticket with support but was hoping I am not the only one or perhaps someone has already found a fix
I should also add. Download station (earlier version 4.3.2) search is working fine on my older TS-210 (just to prove its not ISP or VPN related ;-)
eversonl
Re: Download station 5 BT search not returning results
Post by eversonl »
it may be that the only search which works on the old version is 1337x
unfortunately there is not an addon for that on on diskstation5
wizkid
Post by wizkid »
Same issue here.
Anyone know where to find a compatible version?
ukidrw2115
First post
Post by ukidrw2115 »
I also have the same issue. BT search doesn't work (No results) with my TS-473 running QTS 5.0.0.1858, but does work using an older TS-469L running QTS 4. Raised the issue with QNAP Support (Q-202111-19731) and even though QTS 4 works, QTS 5 doesn't both going through the same Netgear RAX120 router and ISP, support decided ridiculously that is an ISP problem.
Not sure what else to try or do!!
miren2k
Post by miren2k »
are you all using VPNs? I'm having the same issue, but my conclusion is that it's a VPN problem, I'm trying to figure out how to set up a VPN now
:evil: Forever enraged.
Locked
Return to “Download Station and QGet”
