Hi
the most recent version of Download Station has broken the Qget app from working...has anyone got an older version of Download Station then v 5.8.0.192
It might still be in your updates cache folder or if you know anyway to access older files on the qnap website then that would be great too..I just need to role back to any version before 5.8.0.192
Many thanks
Desperately Need older version of Download Station ??
TS-228A
Mirrored Pair 5TB
Mirrored Pair 5TB
Re: Desperately Need old version of Download Station ??
For future purpose...
I would recommend not to update/install any apps (including firmware) online.
Download the file and perform an manual update:
Doing so, you can store all firmware and apps files at a secure place (not at the NAS, if NAS will fail, all is inaccessible).
So you have always the versions you need.
If such an issue happens again, you can easily install your last running version.
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
Re: Desperately Need older version of Download Station ??
ahh brilliant thanks I didn't realise you could pick individual versions with the QTS OS page
TS-228A
Mirrored Pair 5TB
Mirrored Pair 5TB
- OneCD
* merged topics *
@lucky13, please don't post the same question more than once.
