Very low download speed
Hi.
I have TS-431 (old) with two HD (Western Digital 6TB WD Red Pro NAS Internal Hard Drive - 7200 RPM Class, SATA 6 Gb/s, CMR, 256 MB Cache, 3.5" - WD6003FFBX) in mirow raid.
The maximum download speed of torrents is about 5MB/s, what looks me very low with my internet speed (500Mbps).
The NAS connected to a router Asus AC68 by cable.
Why the download so low ? HDs' speed limit ?
If it HD limit , maybe to add some small HD with high speed for temp files ? ....
Re: Very low download speed
Switch to a different torrent program then
Back when I used transmission on my 419p+ I could get 5-8MB/s (maxing out the little ARM processor)...so check what processing power is needed during downloads.
Transmission on my TS-231P pulls down at 20-30MB/s.
Check the CPU and other stats while downloading and see what else is running on your system. Also, check your connection speeds and the rest of your network hardware.
Also, try a public torrent, not a private one, such as a Raspberry Pi image or similar as well as see how well another device/system performs for downloading torrents.
I have only DownloadStation 5 in App Center. TS-431 is so old today, no any updates in App Center for it.
In Resource Monitor I see Download Station takes about 45% processor and total CPU load about 70% (User 30%, System 30%, Other 10%, IO Wait 10%).
Maximum torrent download speed 6MB/s.
My PC from the same router gets 450-500Mbps torrent download.
There is 3rd party repos with x31 compatible torrent programs
download the x31 version of transmission from here
https://www.qnapclub.eu/en/qpkg/976
or here
https://www.myqnap.org/product/transmissionbt-4/
or here
After it downloads 20M I get a message in transmission app "Error: No space left on device" and in QNAP GUI some interfaces crash.
Before I added some torrent I changed download and temp folder to "/Download" , but is looks like the torrent client tried to download it to system partition maybe ?
What I missed ?
uninstall then and try to download the other version (whatever other you chose)
There was complaints about some programs filling system up with stuff ..
I tried both you gave me.
Transmission4 qpkg is 421MB so I assume it also bigger after installation , I installed QTransmission3 with qpkg file 34MB.
After I download torrent 2+GB size I also got the same system crash.
During downloading I didn't see temp file in /Download which I set as target folder. Where it downloaded ....
Both of the websites quoted have more than one transmission qpkg, you can always experiment.
I have not used transmission on QNAP in a while or even have access to a x31 unit... sorry.
I uninstalled and tried to install again and downloaded some file 4GB , again I got the same problem m restart and now the system doesn't start up .
It gave several times sounds and I can't enter to web GUI.
