I am trying to install Logitech Media Server on a TS-110 running QTS 4.2. The instruction for install the ~.qpkg say I should do it in the Web UI under Application Server > QPKG Plug-ins. My QTS 4.2 does not have "Application Server" in the list of fuctions. How do I install a ~.qpkg in QTS 4.2?
Thanks fo any help.
Installing qpkg on QTS 4.2
Re: Installing qpkg on QTS 4.2
Go to APPcenter > install manually.aj1825 wrote:I am trying to install Logitech Media Server on a TS-110 running QTS 4.2. The instruction for install the ~.qpkg say I should do it in the Web UI under Application Server > QPKG Plug-ins. My QTS 4.2 does not have "Application Server" in the list of fuctions. How do I install a ~.qpkg in QTS 4.2?
Thanks fo any help.
In case anyone is a newb like me, for which the above terse response though appreciated, was insufficient ...
- go to AppCenter
- click on Gear icon (near top-right)
- NOTE: You must have Python 2.7 installed FIRST or the compatibility checking tool won't install!
- you can install Python via the "Developer Tools" section of AppCenter
- After CF tool installs successfully, click on "hamburger" icon (top left), then choose item named "CF64" to launch it
HTH,
DH
- go to AppCenter
HTH,
DH
Thanks, i was looking for that!
