Since a few months I own a Qnap TS251+ 2mb. I bought it because it supported JRiver Media Center. I have been using this for years on my PC.
I installed it but lateron it would not upgrade to a newer version. So I uninstalled it. I also bought a master licence from Jriver to register the Qnap version.
When I tried to reinstall MC I noticed it wasn't listed in the HD-station apps anymore!
So where is it? Is Qnap still supporting JRiver Media Center and where can I get it to reinstall?
Thank you for your answer.
Jriver Media Center disappeared
TS251+ 2mb and TS219P+
Re: Jriver Media Center disappeared
same question...does anyone from QNAP like to answer?
Looks like a manual installation is in order
Here is a link to the last build they posted. You will have to install it manually.
http://files.jriver.com/mediacenter/cha ... 86_64.qpkg
Here is a link to the latest MC 21 build for QNAP. Same as above, install manually.
I lurk here from time to time, but this time came looking for info on Jriver on qnap since Jriver will now work with amazon's echo (vocal commands). But what i read here suggest I'm late to the party.
Can qnap tell me the status of Jriver on qnap?
- Trexx
This is a community support forum. If you are looking for a QNAP answer, you will need to open a ticket via http://helpdesk.qnap.com.
QNAP generally only monitors the pre-sales forum.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
http://yabb.jriver.com/interact/index.p ... 418.0.htmlccchuck wrote:I lurk here from time to time, but this time came looking for info on Jriver on qnap since Jriver will now work with amazon's echo (vocal commands). But what i read here suggest I'm late to the party.
MC 22 works perfectly fine on my TS-451+
You'll have to install it manually and QNAP won't provide support for it.
I install MC22 in my TS-451A, when I try to play dsf files, it hangs and stop working. Any hints to resolve this. Thanks in advance!
我從使用 Tapatalk 的 SM-T815C 發送
how do you go about installing it manually?
thanks in advance
David
thanks in advance
David
Re: RE: Re: Jriver Media Center disappeared
Yes, using the link posted above.anotherdavid wrote:how do you go about installing it manually?
thanks in advance
David
