Twonky not avilable after upgrate to 4.3.3
I have just installed firmware 4.3.3 and Twonky server is not longer available. I checked as alternatives, media stream add-on and filemanager sending to recievers but srt subtitles are not shown in this case.
What alternatives do i have?
Thanks.
Thanks.
- Trexx
Re: Twonky not avilable after upgrate to 4.3.3
Buy a personal use license for Twonky and then follow these instructions:
viewtopic.php?f=5&t=129165
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Linux Station is not available on the app store so i cannot Ubuntu so i cannot install Twonky, which was working before without needing any license.
What a mess did qnap!!?? every new upgrade is a dissapointing surprise. All was working before upgrade.
No more twonky with 4.3.3 update
I will re-test the Qnap media Steaming app, maybe is better since the upgrade
or just buy it .. as mentioned above
- Trexx
You do have the option of rolling back to 4.2.x if Twonky is that important and there aren't any other streaming apps that will work for your needs.djlevi wrote:Linux Station is not available on the app store so i cannot Ubuntu so i cannot install Twonky, which was working before without needing any license.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
How can i roll back to 4.2.x? I will maintain all my data?
I checked plex and media streaming app and srt are not shown. Why do i have not the option of Linux Station?
you don't need linux station for twonky, just download the qpgk from the twonky website
http://www.twonkyforum.com/downloads/8.4/
- Trexx
To roll back, you would manually install the latest 4.2.x firmware. Now whether that will be 100% pain-free is a different issue. QNAP did notate in the 4.3.3 release notes that Twonky was no longer supported and recommended using embedded media streaming app.
As for Linux Station, it requires 4GB memory minimum which is likely why you can't install it due to the TS-x69Pro family only supports 3GB.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- Trexx
Good to know, and I see they released an x86_64 version for QTS 4.3dolbyman wrote:you don't need linux station for twonky, just download the qpgk from the twonky website
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- Guapo81
I saw this change coming somewhere mid 2016, that the license would disappear from standard QNAP firmware. Already back then was unable to find it in the app center.djlevi wrote:How can i roll back to 4.2.x? I will maintain all my data?
Started experimenting back then and eventually I switched over completely to PLEX.
In the beginning I was not all that happy with PLEX, but been using it now for like 9 months and must honestly say (in my opinion now) it's a great media server and a lot more advanced than Twonky.
It takes some time getting used to PLEX and adapting your media library to really complement the software of PLEX, but when you bite through it, I at least would never want to go back.
Thing with PLEX is that the DLNA mediaserver part is not all that good (Which was the way I was using Twonky and twonky on that part is really good), but when you adapt all your devices to start using the PLEX apps than this changes.
I'm using the PLEX apps on my computers (Windows, MacOS), Televisions (Samsungs) and my IOS devices and this is working really great in my opinion.
External SRT subs (in my case) are shown without a problem and selectable in the plex app.
Good luck with finding your ideal solution.
QNAP TS-h886-64G 2x Samsung 970PRO NVMe SSD (RAID1, System), 2x Samsung 860 PRO SSD (RAID1, VM) 4x Seagate EXOS X16 16TB (RAID5, Data) - FW: QuTS-hero
QNAP TVS-682-i3-32G 4x HGST HUH728060ALN600 (RAID5, Backup) - FW: QTS
QNAP TVS-463 4x Seagate ST2000VN000 (RAID5, Surveillance, Backup) - FW: QTS
Former units: TS-469Pro, TS-459ProII, TS-269Pro, Qgenie
Thanks for the comments.
Finally i rolled back to firmware 4.2
Alex wasn't working for me, srt subtitles were not available on my Samsung TV using this server.
I tried also install Twonky qpkg but my NAS didn't allowed me getting an error (I tried almost 7 different qpkg versions)
any info on the error thrown?
Nothing explicit, only that the qpkg could not be isntalled
what was your device ?
