My TS110 recently upgraded to 4.2.5 and Twonky no longer works. The twonky app is still on the desktop, and the server is apparently running, but my dlna clients cannot see it. I gather Twonky was removed in 4.3.x but I'm on 4.2.x.
The built in dlna server works ok but doesn't show the .jpg thumbnails, instead it shows thumbs generated from random still frames in the content which looks rubbish. Can I somehow configure it to use .jpg thumbnails?
I hate it when companies remove functionality in fw updates without warning you first. I wouldn't mind if the built in dlna server displayed thumbs properly, but this is a big step backwards.
Twonky no longer working TS110 fw4.2.5
Re: Twonky no longer working TS110 fw4.2.5
free license was removed, twonky needs to be purchased now (check the forum next time before your post please)
after you purchase a license, this is the link to the current version (8.4)
http://www.twonkyforum.com/downloads/8. ... m-x19.qpkg
- Been there, done that
How many times is the same question going to be asked .... nobody knows how to use the search ....
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Some people seem to have problems reading too, I'm still on 4.2.x.
Fixed it anyhow.
Fixed it anyhow.
free twonky was also removed in 4.2.x .. so it does not matter
No it wasn't.
yes it was .. besides finding old archived (3rd party hosted) version with the license key inside, try finding a licensed qpkg for twonky anywhere on the twonky website, app center or qnap website.. you will not
shortly after the announcement all qpkg packages were removed from all official sources, twonky later added unlicensed versions back into their download website
I still have it after upgrading to 4.2.5 yesterday. It was not removed.
check if it is still the full incense or the 30day trail
anyways, if you need to reinstall or upgrade, as said before, all licensed version were removed
