Can someone explain the "Shared Graphics Memory" setting in Control Panel > System > Hardware? Clicking the Help (?) button shows a description pertaining to video transcoding, which is helpful. However, I can't tell whether it's referring to memory devoted to the QNAP Media Station apps, or to all graphics-related computation.
One interpretation is that the graphics hardware uses the system RAM instead of dedicated memory. So the drop-down affects how much system RAM is dedicated to the kernel graphics libraries, which would mean it could affect Plex as well.
The other interpretation is that it affects only QNAP Media Station transcoding. Any ideas?
Does "Shared Graphics Memory" affect Plex?
- Been there, done that
Re: Does "Shared Graphics Memory" affect Plex?
i would imagine the embedded graphics controller .... for whatever it is used for
Production :
TVS-673 4.3.4 0387
4 X 3TB WD RED : 1 X 4TB HGST DESKSTAR R5
32GB
LAN-10G1SR-D, FiberHal for Cisco SFP-10G-SR
NETGEAR ProSAFE SS3300-28X
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
Located detached garage .. cheap offsite solution ...
2nd TS-469L awaiting drives and reassignment for front-line duty .......
TVS-673 4.3.4 0387
32GB
Backup :
TS-469L 4.3.4 0387
4 X 3TB WD RED R5
3GB
- Trexx
No... it has no effect on Plex as Transcoding is currently SW based only.
My understanding is it would only affect any items that leverage the HDMI/graphics output (HD Station/Linux Station/QXL output for VS) that are leveraging the AMD R7 output.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I think this explains a lot. Just booting back into Linux Station after increasing to 2GB, high-res video does look perfect. Before, I could def tell it was not able to handle it. ThanksTrexx wrote:No... it has no effect on Plex as Transcoding is currently SW based only.
how much is the maximum shared memory you can set?
I have 8GB and I see 2GB, if I upgrade to 16GB can I set 4GB of shared memory?
Thanks!
Thanks!
- Trexx
Max amount is 2GB. Even with 32GB, it doesn't change.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
