Good day all,
Can Qnap's DLNA server sort files on the actual filename instead of sorting on mp3-tagname?
Since Twonky is no longer offered, I turned to Qnap's own DLNA server. And it works fine, well ... almost. I use DLNA for listening to my mp3 collection, over my audio receiver. With the 'Media Streaming Add-on' I set it up to list the files in 'Folders'. But when I play the files in a folder they are alpabetically sorted according to the mp3-tagname which is wrong and annoying. I want the files to be played in the right order, according to their actual filenames.
Even better would be if the 'Media Streaming Add-on' would allow the user to select the sorting order of their choice.
I am running firmware 4.3.3.0210 on a TS-251C.
Regards, Peter.
[REQUEST] DLNA file sorting
Re: [REQUEST] DLNA file sorting
just fyi .. you can just reinstall twonky .. (you will have to pay a license fee though)
@Dolbyman
Yes, thank you. I am aware of that. But if Qnap can get sorting in its DLNA-server to work properly, then there is no need to separately install - and pay for - Twonky.
+1
drives me nuts. used twonky before because of this issue
- Trexx
Twonky has been brought back for certain NAS models in the latest release.
See this post for models/details:
viewtopic.php?f=142&t=135500
Paul
UPS: CP AVR1350
UPS: CP AVR1350
unfortunately not for ts-228 (i've supported q16 serial number)
well just buy it then .. before it drives you nuts .. sanity should be worth 20 bucks
