I am new to the NAS world and am looking for suggestions please. I have a QNAP TS-253A 2-Bay NAS PRO Grade w/10TB WD RED PRO
I use Plex Server as my media server to stream my media to my family, I just built a new HTPC specifically to be able to handle multiple transcoding 1080p streams at 1 time. I'm using an ASUS AC3100 Dual Band Gigabit Router and have Plex Sever installed on my new HTPC and have it pointing to my NAS on my network. I've done a little testing outside of my home network and there seem to be no issues with the streaming or buffering on a device that has little resources to be able to transcode, but would running Plex Sever off the NAS directly be a better way to stream my media? I am assuming because my HTPC specs are better than the NAS it would be best to keep it the way I have?
Intel Core i7 6850K (6 x 4.0GHz CPU - 15MB Cache) 12 Core
Asus X99-STRIX-Gaming motherboard
Liquid Cooling
700W - Power Supply w/ Active PFC
Corsair Vengeance LPX DDR4 32GB 3000MHz
Nvidia GeForce GTX EVGA 1050 TI 4GB
Samsung 960 Evo 250GB
Thank you!
(LOOKING FOR SUGGESTIONS) Plex Server on NAS or PC?
- Don
Re: (LOOKING FOR SUGGESTIONS) Plex Server on NAS or PC?
Try it. What do have to lose? Current PLEX QPKGS can be found on the PLEX site.
- Spider99
my 853A struggles to even do one 1080p transcode with Plex or Emby
Tim
TS-853A(16GB): - 4.3.4.0483 - Static volume - Raid5 - 8 x 4TB HGST Deskstar NAS
Windows Server + StableBit Drivepool and Scanner ~115 TB Backup Server
TS-412 & TS-459 Pro II: Retired
Clients: 3 x Windows 10 Pro(64bit)
- Trexx
Yes, keep your pc for Plex Server.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
Thank you everyone! Appreciate the feedback.
- Trexx
Now if you were looking to upgrade your NAS, then there are definitely some higher-end boxes that can handle both NAS & Plex Server duties but it didn't sounds like that was the path you were taking.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
