2019-03-04 11:11:47:103 101349 [Startup] - LOG_SYSTEM: twonkylib_init : *** Starting TwonkyServer (Product Name:Twonky, Version:8.5.1, Build-date:May 29 2018) ***
2019-03-04 11:11:47:103 101394 [Startup] - LOG_SYSTEM: twonkylib_init : *** Platform:qnap_marvell_6281__twonkyforum-qnap-ts219, Snapshot:Twonky_8.5.1_20180521 TA:c5bd20adecfd43fcf30c90b1271d424f773c1060 ***
2019-03-04 11:11:47:103 101330 [Startup] - LOG_SYSTEM: twonkylib_init : using logfile /share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver-log.txt
2019-03-04 11:11:47:103 101325 [Startup] - LOG_SYSTEM: twonkylib_init : Executable file: /share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver
2019-03-04 11:11:47:104 101285 [Startup] - LOG_SYSTEM: twonkylib_init : Command Line Parameters: 6
2019-03-04 11:11:47:104 101277 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 1:-appdata
2019-03-04 11:11:47:104 101313 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 2:/share/MD0_DATA/.qpkg/TwonkyServerEU/appdata
2019-03-04 11:11:47:104 101275 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 3:-mspid
2019-03-04 11:11:47:104 101290 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 4:/tmp/twonkyserver.pid
2019-03-04 11:11:47:104 101277 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 5:-logfile
2019-03-04 11:11:47:104 101326 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 6:/share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver-log.txt
2019-03-04 11:11:47:110 126566 [Startup] - LOG_SYSTEM: upnp_ini_file_check_for_old_inis : exisiting ini file /share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver-default.ini copied to /share/MD0_DATA/.qpkg/TwonkyServerEU/appdata/twonkyserver.ini
2019-03-04 11:11:47:110 126949 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : reading ini settings from /share/MD0_DATA/.qpkg/TwonkyServerEU/appdata/twonkyserver.ini
2019-03-04 11:11:47:111 126758 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : initialsetupdone = 1
2019-03-04 11:11:47:111 126765 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : contentbase = /share
2019-03-04 11:11:47:111 126787 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : contentdir = +A|/Multimedia
2019-03-04 11:11:47:111 126773 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : language = en
2019-03-04 11:11:47:111 126826 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : friendlyname = TwonkyServer [%HOSTNAME%]
2019-03-04 11:11:47:111 126806 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : httpport = 9000
2019-03-04 11:11:47:111 126806 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : enableweb = 2
2019-03-04 11:11:47:111 126809 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : scantime = -1
2019-03-04 11:11:47:112 127475 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : ignoredir = AppleDouble,AppleDB,AppleDesktop,TemporaryItems,.fseventsd,.Spotlight-V100,.Trashes,.Trash,RECYCLED,RECYCLER,RECYCLE.BIN,@Recycle,.AppleDB,.AppleDouble,.AppleDesktop,:2eDS_Store,Network Trash Folder,Temporary Items,TheVolumeSettingsFolder,.@__thumb,.@__desc,:2e,.@__qini,.Qsync,.@upload_cache,.qsync,.qsync_sn,.@qsys,.streams,.digest
2019-03-04 11:13:25:080 1165616 [Important] - LOG_HTTP: rpc_stop_server : stopping server (rc=42)
2019-03-04 11:13:26:549 718637 [Important] - LOG_SYSTEM: upnp_mediaserver_stop : media server stopped
2019-03-04 11:13:27:237 101349 [Startup] - LOG_SYSTEM: twonkylib_init : *** Starting TwonkyServer (Product Name:Twonky, Version:8.5.1, Build-date:May 29 2018) ***
2019-03-04 11:13:27:243 101394 [Startup] - LOG_SYSTEM: twonkylib_init : *** Platform:qnap_marvell_6281__twonkyforum-qnap-ts219, Snapshot:Twonky_8.5.1_20180521 TA:c5bd20adecfd43fcf30c90b1271d424f773c1060 ***
2019-03-04 11:13:27:243 101330 [Startup] - LOG_SYSTEM: twonkylib_init : using logfile /share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver-log.txt
2019-03-04 11:13:27:243 101325 [Startup] - LOG_SYSTEM: twonkylib_init : Executable file: /share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver
2019-03-04 11:13:27:243 101285 [Startup] - LOG_SYSTEM: twonkylib_init : Command Line Parameters: 6
2019-03-04 11:13:27:244 101277 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 1:-appdata
2019-03-04 11:13:27:244 101313 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 2:/share/MD0_DATA/.qpkg/TwonkyServerEU/appdata
2019-03-04 11:13:27:244 101275 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 3:-mspid
2019-03-04 11:13:27:244 101290 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 4:/tmp/twonkyserver.pid
2019-03-04 11:13:27:244 101277 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 5:-logfile
2019-03-04 11:13:27:244 101326 [Startup] - LOG_SYSTEM: twonkylib_init : cmdline 6:/share/MD0_DATA/.qpkg/TwonkyServerEU/twonkyserver-log.txt
2019-03-04 11:13:27:250 142800 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : reading ini settings from /share/MD0_DATA/.qpkg/TwonkyServerEU/appdata/twonkyserver.ini
2019-03-04 11:13:27:250 142653 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : friendlyname = TwonkyServer [%HOSTNAME%]
2019-03-04 11:13:27:250 142619 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : ip =
2019-03-04 11:13:27:250 142630 [Startup] - LOG_SYSTEM: upnp_ini_file_read_properties_from_file : nicrestart = 1
2019-03-04 11:13:28:870 867354 [Error] - LOG_SYSTEM: get_accounting_status_from_lynx_backend : user with license-key
2019-03-04 11:13:53:292 1181406 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:54:032 1185389 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:54:358 1185272 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:54:576 1185627 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:54:909 1185712 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:55:736 1186309 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:56:430 1186721 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:56:946 1186534 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:57:353 1186744 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:57:803 1187040 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:58:147 1187693 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:58:421 1168593 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:59:165 1168880 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:13:59:589 1169154 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:01:088 1169478 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:01:429 1169559 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:01:766 1169769 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:02:214 1170091 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:02:612 1170300 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:03:431 1170614 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:03:971 1170892 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:04:935 1171266 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:05:896 1171653 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:06:562 1171909 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:06:895 1172338 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:07:265 1172355 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:07:678 1172704 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:07:993 1172835 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:08:321 1173030 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:08:613 1173270 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:09:284 1173508 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:09:809 1174075 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:10:190 1174444 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:10:655 1174510 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:11:080 1175007 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:11:453 1174977 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:11:930 1175118 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:12:409 1175583 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:12:794 1175766 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:13:127 1176126 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:13:549 1176338 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:13:905 1176733 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:14:910 1176835 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:15:802 1177011 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:16:253 1177455 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:16:607 1177894 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:16:963 1177901 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:17:257 1178242 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:17:519 1178360 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:18:215 1178928 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:18:655 1178979 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:19:009 1179269 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:19:611 1160102 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:20:649 1160769 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:20:965 1160798 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:21:358 1161093 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:21:696 1161382 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:22:132 1161385 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:22:728 1161673 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:23:081 1161898 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:23:541 1162152 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:23:930 1162428 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:24:488 1162730 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:24:926 1162992 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:25:684 1163216 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:26:271 1163698 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:26:767 1163993 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:27:045 1164085 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:27:427 1175747 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:27:805 1170088 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:28:173 1165490 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:28:616 1165301 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:29:374 1165682 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:29:741 1165713 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:30:403 1166030 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:30:870 1166144 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:31:194 1166439 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:31:550 1166532 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:31:788 1166954 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:32:111 1167030 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:32:554 1167331 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:32:940 1167679 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:33:556 1168020 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:34:354 1168137 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:14:35:463 1168495 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:15:52:537 1190020 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:15:53:018 1169507 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:15:53:732 1169518 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:15:54:095 1169898 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:15:54:439 1170142 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:18:40:022 1232696 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:18:40:806 1212488 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
2019-03-04 11:18:41:733 1192155 [Error] - LOG_CGI: call_cgi_prog : transcoding failed: nResult=-1, size=0
Port trunking is also disabled...
