Manual creation of a m3u playlist
DLNA, AirPlay, Chromecast, PS3, XBOX, iTunes, & other media players
mgoddard
First post
Post by mgoddard »
Hello, I'm trying to create a playlist to be used with my Yamaha devices and the MusicCast app. I can create a *.m3u file and place it in the /Music DLNA share and the app will see the playlist but when I try to use it I get a message that the playlist is empty. The MusicCast app/device can't find the tracks.
I expect the problem is with the file path, but I can't find any documentation on what this needs to be.
I have tried a few variations but none of them work. For example,
#EXTM3U
#EXTINF:200,All Star - Smash Mouth
/Multimedia/Music/Smash Mouth/All Star Smash Hits/01 All Star.m4a
or
#EXTINF:185,Brown Eyed Girl - Van Morrison
/Music/Van Morrison/Bang Masters/01 Brown Eyed Girl.m4a
or
/share/Multimedia/Music/Van Morrison/Bang Masters/01 Brown Eyed Girl.m4a
Does anyone know what the correct path format is?
rmigneron
Re: Manual creation of a m3u playlist
Post by rmigneron »
Hello, have you tried relative path to where the playlist is located ?
for example, on my Synology NAS, the playlists are stored in a "playlists" directory at the root of the shared music directory, the .m3u contains lists of songs all starting with ../ (relative) - in your case, you should have : ../Smash..... as the path.
Hopes this help.
Richard
_______________________________________________
"It doesn't work, because the buttons & controls can't change !",
Steve Jobs, MacWorld 2007 Keynote
avvaVVO
First post
Post by avvaVVO »
mgoddard wrote: Tue May 19, 2020 11:04 am Hello, I'm trying to create a playlist to be used with my Yamaha devices and the MusicCast app. I can create a *.m3u file and place it in the /Music DLNA share and the app will see the playlist but when I try to use it I get a message that the playlist is empty. The MusicCast app/device can't find the tracks.
I guess you using default built-in DLNA server.
I use:
Yamaha R-N402 as network player
QNAP TS-459 as NAS
MinimServer as DLNA (non-default)
MinimServer has menu "Playlists"
MusicCast app able to see playlists - content playback properly.
Return to “Media Streaming”
