Kodi 19 - TrueHD
DLNA, AirPlay, Chromecast, PS3, XBOX, iTunes, & other media players
ray105
Kodi 19 - TrueHD
Post by ray105 »
Anybody has any idea/method to enable the Kodi (in Qnap NAS) to be able to play movie with TrueHD/Atmos sound effect?
dolbyman
Re: Kodi 19 - TrueHD
Post by dolbyman »
As you posted in media streaming (and not playback)...you need to post your playback/software hardware info
I can play TrueHD (w Atmos) just fine from both my 419p+ and my 951X ... with external players of course (Kodi/Plex/DLNA)
Dubov
Post by Dubov »
ray105 wrote: Sun May 09, 2021 4:19 pm Anybody has any idea/method to enable the Kodi (in Qnap NAS) to be able to play movie with TrueHD/Atmos sound effect?
You make it difficult to help yourself because you write so little information.
If you use setup NAS HDMI out » receiver » TV and no sound then check KODI settings-system-audio-audio passthrough. Enable passthrough and TrueHD capable receiver.
If you do not see these options enable expert level in KODI.
If you use setup NAS HDMI out » TV » receiver then additionally check if your TV have ARC or eARC. You need eARC for TrueHD.
Model: TS-453D
RAM: Crucial 16GB 2400MHz DDR4 CL17 SODIMM CT16G4SFD824A
Disks: 4x8TB Western Digital Red 3.5" WD80EFAX
Other devices: Netgear Nighthawk® AX6000 WiFi Router (RAX120) | QNAP QSW-1105-5T 2.5GbE switch
Return to “Media Streaming”
