DLNA, AirPlay, Chromecast, PS3, XBOX, iTunes, & other media players
boacon
Posts: 15 Joined: Wed Jan 02, 2019 11:52 pm
Post
by boacon » Fri Aug 06, 2021 1:37 am
QNAP TS-251+
Hello - I am trying to use ffmpeg to transcode surveillance video from Surveillance Station to scale them down and from .avi to .mp4. I noticed that the command used when transcoded through MediaCenter (or CAYIN) is the command below (taken from running `top`).
/opt/cdx/bin/ffmpeg -y -vaapi_device /dev/dri/renderD128 -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i /tmp/23395_1628124822.avi -vf format=nv12|vaapi,hwupload,scale_vaapi=w=640:h=480 -map 0:v:0? -c:v h264_vaapi -map 0:a:0? -c:a aac -ab 64000 -ac 2 -f mp4 /share/CE_CACHEDEV1_DATA/Security-Cameras/test/16/.@__thumb/temp/.24471_1191171840_1628124819_RE5J8a.2021-01-28_15-35-01~15-40-01.avi
I have found that the ffmpeg command is located in `/usr/bin/ffmpeg` and have used that location to run the command above. Though when I try to run it I keep getting the following error message:
Unrecognized option 'vaapi_device'.
Basically I am asking, how do I perform video transcoding using my QNAP NAS from the CLI? More specifically I'd like to script that and ensure it uses hardware acceleration as well.
Thanks!
QNAP TS-251+ 4GB RAM
dolbyman
Posts: 35033 Joined: Sat Feb 12, 2011 2:11 am
Post
by dolbyman » Fri Aug 06, 2021 1:53 am
The regular ffmpeg was crippled (hence the introduction of Cayin... why? ..maybe commercial codec licensing issues, QNAP never said anything )
So install ffmpeg from qnapclub and try it again.
boacon
Post
by boacon » Fri Aug 06, 2021 1:58 am
But the NAS itself is somehow able to run these transcriptions using ffmpeg. Is there just a different binary that it is using, or in a different location?
dolbyman
Post
by dolbyman » Fri Aug 06, 2021 1:59 am
see the link I posted
boacon
Post
by boacon » Fri Aug 06, 2021 2:24 am
Firstly - Thanks for your quick responses. I truly appreciate it.
So I downloaded and installed that version from qnapclub. I am still getting that "Unrecognized option 'vaapi_device'." error.
I guess my question is shouldn't I be able to run the same exact command that MediaCenter is using to get the same result? And why is that not working?
dolbyman
Post
by dolbyman » Fri Aug 06, 2021 2:40 am
if you do a
is the vaapi option enabled or even present?
I only have cuvid (default qnap ffmpeg) enabled (TS-853BU)
ffmpeg version 3.3.6 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.9.2 (Debian 4.9.2-10)
configuration: --enable-cross-compile --arch=i686 --target-os=linux --disable-yasm --disable-static --enable-shared --enable-gpl --enable-libmp3lame --disable-libx264 --enable-libsoxr --enable-version3 --enable-nonfree --disable-openssl --disable-decoder=ac3 --disable-decoder=ac3_fixed --disable-decoder=eac3 --disable-decoder=dca --disable-decoder=truehd --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-encoder=dca --disable-decoder=hevc --disable-decoder=hevc_cuvid --disable-encoder=hevc_nvenc --disable-encoder=nvenc_hevc --disable-decoder=h264 --disable-decoder=h264_cuvid --disable-encoder=libx264 --disable-encoder=libx264rgb --disable-encoder=h264_nvenc --disable-encoder=nvenc --disable-encoder=nvenc_h264 --disable-decoder=mpeg2video --disable-decoder=mpegvideo --disable-decoder=mpeg2_cuvid --disable-encoder=mpeg2video --disable-decoder=mpeg4 --disable-decoder=mpeg4_cuvid --disable-decoder=msmpeg4v1 --disable-decoder=msmpeg4v2 --disable-decoder=msmpeg4v3 --disable-encoder=mpeg4 --disable-encoder=msmpeg4v2 --disable-encoder=msmpeg4v3 --disable-decoder=mvc1 --disable-decoder=vc1 --disable-decoder=vc1_cuvid --disable-decoder=vc1image --disable-decoder=aac --disable-decoder=aac_fixed --disable-decoder=aac_latm --disable-encoder=aac --extra-ldflags='-L/root/git/1.4.x/x86_64/ndk/LinkFS/usr/lib -L/root/git/1.4.x/x86_64/ndk/Model/TS-X53/build/RootFS/usr/local/medialibrary/lib -Wl,--rpath -Wl,/usr/local/medialibrary/lib' --extra-cflags='-I/root/git/1.4.x/x86_64/ndk/LinkFS/usr/include -I/root/git/1.4.x/x86_64/ndk/Model/TS-X53/build/RootFS/usr/local/medialibrary/include -D_GNU_SOURCE -DQNAP' --prefix=/root/git/1.4.x/x86_64/ndk/Model/TS-X53/build/RootFS/usr/local/medialibrary
libavutil 55. 58.100 / 55. 58.100
libavcodec 57. 89.100 / 57. 89.100
libavformat 57. 71.100 / 57. 71.100
libavdevice 57. 6.100 / 57. 6.100
libavfilter 6. 82.100 / 6. 82.100
libswscale 4. 6.100 / 4. 6.100
libswresample 2. 7.100 / 2. 7.100
libpostproc 54. 5.100 / 54. 5.100
Hardware acceleration methods:
cuvid
Same result on my 951X btw, QSV hardware transcoding runs just fine on that one though (Plex)
dolbyman on Fri Aug 06, 2021 2:52 am, edited 1 time in total.
boacon
Post
by boacon » Fri Aug 06, 2021 2:51 am
So It seems like I have cuvid also:
# ffmpeg -hwaccels
cuvid
The reason I got vaapi was from the earlier command I saw running.
When I run the same for the ffmpeg version downloaded from qnapclub I see "vdpau".
dolbyman
Post
by dolbyman » Fri Aug 06, 2021 2:55 am
according to this
http://trac.ffmpeg.org/wiki/HWAccelIntro
Both are associated with Nvidia and should not be usable by intel QSV.
According to that list it should be VAAPI or OpenCL.
boacon
Post
by boacon » Fri Aug 06, 2021 3:19 am
Thanks for that suggestion. Not sure if that last link would actually end up working the way things are going. I just feel like since you can do the transcription on the NAS via the UI, there has got to be a way to do it via the CLI with what is already existing on the NAS.
I tried running it again via the UI and this time ran `ps aux |grep ffmepg` and see the following. There seems to be an agent running as well. Not sure of the purpose of that.
# ps aux | grep ffmpeg
5302 admin 11660 S /opt/cdx/bin/cdx-ffmpeg-agent -m mp4 -s width=640,height=480 -ac 2 -ab 64000 -fs /share/CE_CACHEDEV1_DATA/.system/transcode/24471_1174386432_1628190726_YJZlmV/24471_1174386432_1628190726_n7KMEx -i /share/CE_CACHEDEV1_DATA/Security-Cameras/test/2021-01-28_15-00-01~15-05-00.avi -o /share/CE_CACHEDEV1_DATA/Security-Cameras/test/15/.@__thumb/temp/.24471_1174386432_1628190726_Ta9agj.2021-01-28_15-00-01~15-05-00.avi
5821 admin 62008 S /opt/cdx/bin/ffmpeg -y -vaapi_device /dev/dri/renderD128 -hwaccel vaapi -hwaccel_output_format vaapi -noautorotate -i /tmp/5301_1628190729.avi -vf format=nv12|vaapi,hwupload,scale_vaapi=w=640:h=480 -map 0:v:0? -c:v h264_vaapi -map 0:a:0? -c:a aac -ab 64000 -ac 2 -f mp4 /share/CE_CACHEDEV1_DATA/Security-Cameras/test/.@__thumb/temp/.24471_1174386432_1628190726_Ta9agj.2021-01-28_15-00-01~15-05-00.avi
I opened up a ticket with QNAP to see if they can help.
dolbyman
Post
by dolbyman » Fri Aug 06, 2021 3:48 am
I hope QNAP can help ... I have a feeling they will not want to (due to licensing restrictions) .. but fingers crossed.
FastLaneJB
Posts: 19 Joined: Sat Aug 14, 2021 3:03 am
Post
by FastLaneJB » Wed Oct 20, 2021 4:17 am
I do transcoding on my NAS but I've approached this a different way by just using a container and mounting the directories I need to do it. I'm using docker but you could spin up an LXD container also to do quite easily. That way your not having to fiddle with or worry about the software on the NAS.
