Jellyfin installation on Qnap TS-230 without qpkg package
I have QNAP TS-230 (arm64) and before i used Jellyfin 10.7.6 which has been installed using qpkg file (from repo qnap.eu).
But after last Jellyfin update on android device I received info that Jellyfin 10.7.6 can not work with new android jellyfin, please install Jellyfin 10.8.0
I tried to find Jellyfin 10.8 in qpkf package but no chance.
I wondered if it was possible to install the Jellyfin on my NAS TS-230 without a qpkg file.
After several days of suffering))) I installed the Jellyfin on my NAS.
If anyone is interested in this topic, I can write instructions on how I did it.
- Gaudi
- Easy as a breeze
Re: Jellyfin installation on Qnap TS-230 without qpkg package
I will appreciate if you could post the steps to install/update.
I do have 10.8.1-1 version (https://github.com/pdulvp/jellyfin-qnap) installed, but am willing to understand other installation method to upgrade it.
Thank you
Thank you
Have you got arm64 arch or Intel?
Because link which you posted is only for Intel (https://github.com/pdulvp/jellyfin-qnap)?
But any way I think that these steps are the same for any arch.
Also I will ask you - do you know Container Station app for Qnap NAS ? It is simple way to use Jellyfin 10.8.3 without my hard instruction)))
But I was just interested in running the program myself
- Gaudi
- Easy as a breeze
My NAS is an old TS-469 Pro, so it is Intel x64.serge35 wrote:Have you got arm64 arch or Intel?
My old NAS does not support Container Station. I have a new TA-473a which I have not yet got the chance to install.serge35 wrote:But any way I think that these steps are the same for any arch.
Nevertheless your instructions will be valuable if I choose to go the .qpkg road.
Looks forward to them.
Step 1
Ok, first of all check where Qnap saves installed qpkg packages on your HDD/SSD
On my SSD it is: /share/CACHEDEV2_DATA/.qpkg/
Here you must see all app which have been installed via App Center of Qnap
Then make here new dir Jellyfin_new
Go into this dir - cd Jellyfin_new
Then from https://repo.jellyfin.org/releases/server/linux/stable/
download tar.gz file according to your arc
make unzip here in the dir Jellyfin_new
tar xvzf *.tar.gz
you wll have new dir jellyfin_10.8.3
Create a symbolic link to the Jellyfin 10.8.3 directory
ln -s jellyfin_10.8.3 jellyfin
then make four new dirs
mkdir data cache config log
then isung vi editor make new file Jellyfin.sh
vi Jellyfin.sh
Here paste the following commands:
#!/bin/sh
JELLYFINDIR="/share/CACHEDEV2_DATA/.qpkg/Jellyfin_new"
FFMPEGDIR="/share/CACHEDEV2_DATA/.qpkg/Jellyfin_new/bin"
$JELLYFINDIR/jellyfin/jellyfin \
-d $JELLYFINDIR/data \
-C $JELLYFINDIR/cache \
-c $JELLYFINDIR/config \
-l $JELLYFINDIR/log \
--ffmpeg $FFMPEGDIR/ffmpeg
After make
chmod u+x Jellyfin.sh
Try to execute
./Jellyfin.sh
tar xvzf *.tar.gz
vi Jellyfin.sh
#!/bin/sh
After make
Try to execute
./Jellyfin.sh
- OneCD
Something to be aware of: one of Malware Remover's earliest validation checks was to examine .qpkg for manually-created directories and remove them.
I don't know if it still does this check, but Malware Remover checks have historically been cumulative.
no, on my nas directory still exists
- OneCD
Great!
BTW: maybe consider building this into a new QPKG? You've already done the hardest part: getting Jellyfin running.
I tried))) but I did not find good manual(((
- Gaudi
- Easy as a breeze
Thank you for your instructions.
It is similar to what I have tried to do, but run into problems with ffmpeg directory: it is present in the .qpkg created directories, but is not present in the server package downloaded.
This I got an error and I reverted back to original .qpkg.
I will give it a try and comment.
Also, I tried to follow instructions to create a working .qpkg myself, but QDK instructions were unclear (I tried to set up a WSL as indicated in pdulvp GitHub repo to compile, but failed at some point).
Regards
Regards
- OneCD
Yep, QNAP's documentation makes it look a lot harder than it really is.
Try starting with my template QPKG, and develop from there.
Regading ffmpeg directory it will be the next Step 2Gaudi wrote: ↑Mon Aug 15, 2022 2:35 am Thank you for your instructions.
Regards
Make Step 1 and tell me result
Step 2
About ffmpeg directory
Here find for your arc ffmpeg zip https://johnvansickle.com/ffmpeg/
Unzip it
You will have some files and direcory mainpages
Then make directory bin in directory Jellyfin_new (from Step 1)
Copy all files and directory mainpages to the Jellyfin_new
Unzip it
Thank you for the invitation! I will study it. If I will have some questions I will ask you to help me)))OneCD wrote: ↑Mon Aug 15, 2022 2:36 amYep, QNAP's documentation makes it look a lot harder than it really is.
