Hi guys,
Small problem with the Q Apps, they can't find my NAS. I know the phone and apps are ok as on my own network/NAS(TS-251) I have no problems. My stepdad recently moved provider and changed router and since then I can't discover the NAS (TS-453).
I can add the NAS manually using the IP address or the QNAPCloud ID, but after that no joy.
It's not a big deal, but I'd like to crack it.
Any help much appreciated.
All Q Apps cannot find NAS
Re: All Q Apps cannot find NAS
without knowing what hardware is involved its hard to help
check if the router isolates clients and/or only allows them internet access but not lan
Is it possible that the new router needs some sort of special accommodation in order to discover the NAS?
Asking because I have a similar issue.
- Easy as a breeze
When you access the nas with the IP address, are you accessing it with the local IP or global IP. Could this be a port forwarding issue?
Or it could be an ISP that does Carrier Grade NAT..
https://en.wikipedia.org/wiki/Carrier-grade_NAT
That would prohibit usage
