Hi !
I'm facing a strange issue. Using chrome on hd station, I can't type any number or special character through my phone. They end up being displayed as other characters (5 => " for example).
Is anyone else facing the same problem ?
Can't type numbers and @ with qremote on chrome
Re: Can't type numbers and @ with qremote on chrome
Hi !
I know it's old stuff and I hope you find how to solve it, but - if not - here is the fix.
In HD Station, go to Settings->Preferences and then change the Input value to English (US). Then the qremote app keyboard will exactly match.
You don't have to change the language setting, just the Input (Entree in French)
Hope it'll help
Hope it'll help
Damn I just changed it this WE
Thanks for the help anyway
