I have a TS-1079 Pro running QTS 4.3.2.
I have background upload turned on my iphone. There is a message that pops up saying you need to run QTS 4.3.0 or greater to turn on rename function.
Since I'm running 4.3.2, why can't I see the rename options for background uploads?
Thanks!
QFile Background Upload - Rename
- Easy as a breeze
Re: QFile Background Upload - Rename
I am running 4.3.3 beta and I don't get that popup message about needing to run QTS 4.3.0 to turn on the rename function. On my qfile app, the only options for upload or download I see are overwrite and Skip. I don't see a Rename option either but I don't get the same pop up you get.
when do you get that popup message
