Anyone try Qmanager on ios11.
Doesn’t seem to work for me.
QMANAGER not working on ios11
Re: QMANAGER not working on ios11
what exactly does not work ?
more info please
more info please
- Don
Since IOS11 isn't publicly available yet I doubt you will get many people that have tried it yet.
The menu at the top left corner does not open when you tap on the ‘hamburger’ so can’t access most of the features. The two tabs on the main screen do work so hopefully it just needs a small tweak.
TS-419P 4.3.3.1315 Build 20200611
- Trexx
Confirm not working on latest IOS 11 beta release. Also newly released QSirch doesn't work properly under IOS 11 beta either (screen sizing is off, etc.).
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I had this problem to but I didn't found the solution yet. Maybe there are some news about it?
I think that future is ours and we need to create something more proggresive. Because after age of inventions we stand on the spot and we are consuming. We need to change this situation!
- Trexx
Qsirch has been fixed. Please submit a Helpdesk ticket > Mobile Apps with Qmanager issue.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
