Dear all,
I need some support: When I use the Auto-Upload function with Qfile to save my iPhone photos on the NAS the time stamp of the photo ist not correct. Creation Date, Date of last change or the original date (EXIF) are not correct.
Can you give me an hint, if it is possible to transport the correct informations with the photos.
Thanks for help.
Bert
If necessary:
iPhone 7
Qfile 2.10.3.1015
HS-251+
Qfile / iOS: Wrong time stamp when auto Upload photos
Re: Qfile / iOS: Wrong time stamp when auto Upload photos
Same here.
After upload the photos to the NAS , some old photos are arranged at the wrong time, but they are correct on the iPhone.
When the photo is uploaded, the name is changed according to the time and the name is correct, but the shooting time in the photo data is wrong.
That’s odd.
That’s odd.
I have the same problem as well! Neither HEIC nor JPEG photos uploads with the correct timestamp. Any workaround?
Same issue here. Qfile for iOS upload files with wrong modify time, automatically or manually. The wrong modify time will cause existing files in the target overwritten or new files renamed.
It is wired the modify time doesn't match any existing timestamp on QNAP ext4 file system.
I turned back to PhotoSync.
