Hello all,
I would be very grateful if someone could let me know if the mobile music app, qmusic allows you to view and change song ratings.
Many thanks
Ian
Update song ratings
Re: Update song ratings
I realise this post has been here nearly 8 years but it's the closest I can find for my issue!!
The answer to the question would be yes, but mine doesn't work for me on Android, reporting a permission error.
Editing the ratings seems possible my seeing the info of a track then pressing on the heart icons next to rating. You then choose the rating and click OK. At this point for me I see the error pop-up at the bottom.
My user account, and the one I run Multimedia services for, has full read-write permission on the Multimedia/Music folder.
My app version is 3.0.1.1228 running on Sony Xperia 5 II with Android 11.
after 8 years chances are that things have changed, so no need to post
marked for closure due to necroposting
