Remote ISCSI Storage Pools disappeared after upgrade
iSCSI related applications
lzep1968
Post by lzep1968 »
Hi all,
I have TVS-671 with six local disks and a TS-451+ with four local disks. On the TVS-451+, I have two storage pools created and I had mapped those over to two storage pools on the TVS-671 (using the VJBOD feature). The two storage pools showed up on my TVS-671.
I recently upgraded to 4.4.3.1439 on both NAS devices and after the upgrades, I found that both remote storage pools were missing from my TVS-671. The ISCSI connection is still active and enabled between the TVS-671 and TS-451+, but there are no longer any storage pools or volumes defined.
When I try to re-create the Storage Pool on the TVS-671, it warns me that it will format the volume, losing all data... which I obviously don't want it to do.
Is there any way that I can re-map the remote storage pools from the TS-451+ without losing the data on those VJOBDs?
Thanks in advance.
Return to “iSCSI – Target & Virtual Disk”
