We got a TVS-1271U-RP with a UX-800U expansion box.
Look like we maybe have two drive on a raid 5 that stopped working and the box did not have the time to use the spare disk to rebuilt itself.
Unit is currently in readonly, all ISCSI target have unmounted, Raid ground 2 ( External UX-800U ) is currently in rebuilding.
In SSH I see that the rebuilding is VERY SLOW
[~] # cat /proc/mdstat
md2 : active (read-only) raid5 sdp3[2] sdq3[4] sdr3[3] sds3[1](F)
23412214272 blocks super 1.0 level 5, 512k chunk, algorithm 2 [4/2] [__UU]
[>....................] recovery = 1.4% (113491648/7804071424) finish=2792760.7min speed=45K/sec
[~] # mdadm --misc --detail /dev/md2
/dev/md2:
Version : 1.0
Creation Time : Mon Oct 26 16:05:11 2020
Raid Level : raid5
Array Size : 23412214272 (22327.63 GiB 23974.11 GB)
Used Dev Size : 7804071424 (7442.54 GiB 7991.37 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed Apr 14 21:22:18 2021
State : active, FAILED, recovering, Rescue
Active Devices : 2
Working Devices : 3
Failed Devices : 1
Spare Devices : 1
Layout : left-symmetric
Chunk Size : 512K
Rebuild Status : 1% complete
UUID : 008a5f85:b13dc205:658f6902:b017f5a9
Events : 1112
Number Major Minor RaidDevice State
4 65 3 0 spare rebuilding /dev/sdq3
1 65 35 1 faulty /dev/sds3
2 8 243 2 active sync /dev/sdp3
3 65 19 3 active sync /dev/sdr3
The ISCSI LAN is block base ( not file base ), is there a way to access the data in READ ONLY and copy it on an other QNAP ?
[~] # lvm lvdisplay
Found duplicate PV zli15akjdnDWwZDraFwBfTZODEycUPiN: using /dev/drbd1 not /dev/md1
Using duplicate PV /dev/drbd1 from subsystem DRBD, ignoring /dev/md1
WARNING: Device for PV 5i8L6s-8tis-ep0f-5Xjc-ZDyo-a6Wh-qwE4qt not found or rejected by a filter.
--- Logical volume ---
LV Path /dev/vg1/lv288
LV Name lv288
VG Name vg1
LV UUID O0CXlk-mIr3-ZYOx-yd15-oU3X-aWsm-7K7PU6
LV Write Access read/write
LV Creation host, time QNAP-SPLN-1, 2017-07-13 09:34:09 -0400
LV Pool name tp1
Failed to parse thin params: .
LV Status available
# open 1
LV Size 50.00 TiB
Current LE 13107200
Segments 1
Allocation inherit
Read ahead sectors 8192
Block device 253:9
I have found a documentation for file base ISCSI LUN ( https://www.it-support-singapore.com/it ... -recovery/ ) , but on my side it's BLOC BASE ISCSI lun.
Can you help ?
I need to access this LUN that host XenServer VM
QNAP Raid Group 2 ( UX-800U ) disk failed then ISCSI DOWN
Re: QNAP Raid Group 2 ( UX-800U ) disk failed then ISCSI DOWN
Had a call with QNAP support after I open a ticked on their side ... look like I just have to be very patient that the raid group rebuild himself
