Hi all!
The situation is the following:
- 2 QNAP TS-453BU-RP-4G
- 1 VM on a VMware host using 1 datastore
Is there a way to have redundancy for the VMware datastore using two QNAP NAS? So if a NAS goes down the datastore is "published" by the second NAS.
maybe someone has had experiences like this and can help me understand if its possible and how.
Thanks!
Redundancy datastore for a VMware Datastore
Re: Redundancy datastore for a VMware Datastore
IHMO - no.
As far as I know QNAP do not offer a HA solution like a cluster or something else.
You can setup a replication job between 2 NAS, i.e. a backup or a sync job.
But this is not for hot swapping. May be as a "cold standby", you may need to modify mountpoints for accessing.
In case of iSCSI you need a new mapping, and next question is if VMware accepts a new volume ID or if more steps are needed.
So again, no, no HA solution I would recommend any company to use.
Regards
Regards
Deadbolt - READ 1st post!!!
Deadbolt - information
VPN=VPN? No!
www.raidisnotabackup.com
VPN=VPN? No!
