I used to be able to see the volume in disk management just las week.
The only change I made was to do port trunking on the NAS with a lag aggregation group on the switch.
Would this have had an effect?
I have reconnected providing chaps information. I can connect with other servers with the same effect of it not showing up in disk management.
Tim
iSCSI - Connecting on server but now showing in disk management
Re: iSCSI - Connecting on server but now showing in disk management
Not sure exactly what the issue was...
I undid the lag group on the switch and returned the nas to 2 ip addresses.
Then after much consternation resorted to rebooting the NAS.
That did the trick. The iSCSI drives returned to the server.
I will investigate further and report back.
