ISCSI Virtual DISK
iSCSI related applications
robutech
ISCSI Virtual DISK
Post by robutech »
Hello
Following situation:
QNAP 809 Pro Turbo with Thecus I5500 ISCSI Nas Server
Im making a virtual disc with thecus server and the harddisk is correct formated with ext3.
When im copie files from public to thecus (VD), there is a very bad delivery from 40-50 mb/sec. After a short time the QNAP crashes. In eventlog there is nothing usefull, just that lan link is down.
After a new start from qnap, it's working again.
Is there any solution for this problem? Is this problem popular?
Thanx for every help.
Regeards Robutech
QNAPRobert
Re: ISCSI Virtual DISK
Post by QNAPRobert »
Correct me if I misunderstood you:
809Pro takes in a virtual disk which is actually on Thecus.
Copying files from Public share folder to the virtual disk share folder (VD) is running at 40~50 mbs and after a while the QNAP
LAN port would be down.
I suppose you move the files by web file manager?
robutech
Post by robutech »
Hi QNAPRobert
Sorry for my bad english!
This is correctly, its identical from WebManger to Copy or Copy from Windows Explorer.
The QNAP will crash after a short time, the lan link is down because the QNAP is Crash and not the Lan is not Working!
Thecus have not a Problem and its Stabile! QNAP have a Problem with VD
Return to “iSCSI – Target & Virtual Disk”
