TS-439 Pro II iSCSI and vSphere/VMware
- willemsej
Ok new start. I want to use a TS-439 on VSphere and on iSCSI. I want to use the device filled with 4 disks and create a RAID5 and format the device and create a EXT4 partition, after that I create the whole disk into a iSCSI device.
After that I disable the 'write cache for EXT4'. I will use the firmware Version 3.2.3 Build0209 (2010/2/9).
Then I follow the 'How to use QNAP NAS as a VMWare datastore using iSCSI' PDF.
I will use a Port trunk on the device with Balance-alb (Adaptive Load Balancing) as I will use a non managed Netgear GS116 16-Poort Gigabit Switch.
Hope this project will have a positive outcome, please comment?
What I read on the firmware Update date 2010/2/9 Version 3.2.3 Build0209 for the QNAP TS-439 Pro II Turbo NAS,
http://www.qnap.com/download_detail.asp ... ame=Latest
I want to create of all the 4 disks a RAID 5 and a full iSCI volume. Will this cause any problems as I read,
[Known Issues]
- Free disk szie UI error when creating an iSCSI Target with less than 1GB free size.
Strange?
Regards John
http://www.qnap.com/pro_features.asp
[Known Issues]
Strange?
Regards John
- petur
- Moderator
Re: TS-439 Pro II iSCSI and vSphere/VMware
The known issue is only a userinterface bug (display), nothing functional. What you are going to do should work. Note that for the moment there is no way (yet) to backup iSCSI volumes, I think they are working on this...
Praat je liever over QNAP in het Nederlands?
Liever een community bij jou in de buurt?
Kom naar QNAPclub België/Nederland
- willemsej
Thanks I will go forward and let you know the outcome.petur wrote:The known issue is only a userinterface bug (display), nothing functional. What you are going to do should work. Note that for the moment there is no way (yet) to backup iSCSI volumes, I think they are working on this...
Regards John
- willemsej
Switching and testing with the TS-439 Pro II did the trick.
Regards John
Regards John
Hi Willemsej,
I would like to buy a TS-439 Pro II in order to create a small lab at home with several other colleagues. Can you tell me how many Virtual Machines that are installed on the iSCSI hard drive you are running at the same time?
Thank you in advance,
Didier
Didier
- willemsej
I switched back to NFS.
Actually, the most important for me is more to know if this NAS will be able to handle multiple VMs and what is the maximum of simultaneous VM's
This is what I would like to do:
The workload per VM will be low because this is not a production environment.
Do you thing the following configuration will be possible with all machines running at the same time?
-8 Servers 2008 R2: 3 Domain Controller, 1 WSUS, 1 SQL 2008, 1 SharePoint Server 2007, 2 Exchange server 2010
-3 Servers 2003 R2:
-3 Win 7
-2 Win XP
Other important information:
Two PCs will be connected to the QNAP, each of them with a Gigabit connection.
The Hypervisor will be Hyper-V on both computers.
Didier
-3 Servers 2003 R2:
-3 Win 7
-2 Win XP
Didier
- Easy as a breeze
Nope that won't work!didier3001 wrote: Do you thing the following configuration will be possible with all machines running at the same time?
-3 Servers 2003 R2:
-3 Win 7
-2 Win XP
Only QNAP with SSDs can largely sustain the IO load you have here (with thin disk provisioning thought)
You should look at SAN devices with disk controller with R/W cache.
NAS+NFS won't work on Hyper-V.
NAS+iSCSI won't work neither, too much overhead for so many VMs.
I wish I was a virtual machine!
VMware vExpert 2010, 2011 and 2012
Subscribe to my public Blog
Read my articles at VMware Planet v12n
Follow me on Twitter
How To Get wiper.sh Running On QNAP Storage Devices To TRIM SSDs?
What’s Best EXT3 or EXT4 For My NFS Datastores?
Chunk Size Of a RAID0 Volume On a QNAP NAS – What’s The Sweet Spot?
IOPS, RAID and Array Calculator/Estimator
One Of The Most Powerful Shuttle Barebone For My VMware Home Lab
Benchmark Tools – What I Use
How To Use QNAP NAS As A VMware Datastore Via NFS
- willemsej
Wow more then 10 Servers. I use it here with 5 Servers, low load just for test.
Regards John.
Regards John.
Thank you for sharing your experience.
If this number of virtual machines won't work. Do you know what could be the maximum supported? Remember that this is just a test network. All VMs have really low workload.
Didier
Didier
- Easy as a breeze
To calculate that you need formulas... Read these 3 postsdidier3001 wrote:Do you know what could be the maximum supported? Remember that this is just a test network. All VMs have really low workload.
->http://deinoscloud.wordpress.com/2009/0 ... disk-iops/
->http://deinoscloud.wordpress.com/2009/0 ... your-iops/
->http://forum.qnap.com/viewtopic.php?f=199&t=27843
First one will tell you what you can expect in terms of raw performance of your disks.
The second one will tell how to calculate the maximum IOPS you can achieve with your current virtual environment. Compare that number to what you got with the disk IOPS formula.
Third one, there is a trade-off using RAID volumes. It has a serious impact on IOPS. Again depending of your choices (disk types, RAID types, ESX queue depth, IOPS produced by VMs) and with the formulas you can get an clear idea of what you can expect from your QNAP device and virtual environment.
Hi PiroNet,
Thank you very much for your advices. I read everything and it's interesting. I found another interesting document from VMware:
http://www.vmware.com/files/pdf/VMware_ ... 120508.pdf
I just launched some performance counters on my existing Virtual Machines and I will collect some data during a few days and then I will try to estimate what I really need in term of HDD performance.
Thank you again,
Didier
Thank you again,
Didier
What can you recommend that is closest to the ts-459 in price?PiroNet wrote: You should look at SAN devices with disk controller with R/W cache.
- Easy as a breeze
Within the SOHO market I'm afraid there is none that I'm aware off. Alone the iSCSI HBA + a R/W cache module of 1GB backed up with batteries is the price of a TS-459!oma wrote:What can you recommend that is closest to the ts-459 in price?
If you can afford it, HP MSA2000i G2. Its a SAN device! And not a NAS device that has a software based iSCSI with definitely some overhead. That's why you won''t find iSCSI HBAs in a NAS device.
