Dashboard resource monitor not working
Hey guys,
I upgraded my TS-251 memory from 1 gig to 8 gigs using:
Crucial 8GB Kit (4GBx2) DDR3 1600 MT/s (PC3 - 12800) CL11 SODIMM Notebook Memory Modules CT2KIT51264BF160B / CT2CP51264BF160B
After the upgrade, when i click on Dashboard, the cpu and ram in the resource monitor stopped working.
It is only displaying "--%"
Anyone else having this issue?
- schumaku
Re: Dashboard resource monitor not working
Firmware version, build number, screenshot?
Several similar reports in the forum already. Different effects on QTS 4.1.4 vs. QTS 4.2 and/or depending on hardware model variant.
- Moogle Stiltzkin
should be the latest
https://www.qnap.com/i/en/releasenotes/ ... t_choose=2QTS4.2.0 Build 1023
( 2015/10/24 )
[Bug Fixes]
- Fixed an issue where administrator group users could not access Download Station after updating to 4.2.0.
- Fixed an issue where users could not upload files when sharing folders and sharing transcoded videos are enabled.
- Fixed an issue where the wizard for creating RTRR backup jobs that backup to remote Windows via CIFS/SMB would fail during testing.
- Access rights will no longer be reset to default when unplugging and then plugging in a USB storage device.
- Fixed an issue where the refresh icon keeps running on the Percent Used column after creating an iSCSI LUN.
- Fixed an issue where after installing the app Domotz the Storage Manager Volume-LUN status is always showing the loading icon.
- Fixed an issue where a Thin Volume would occasionally report that it is being formatted.
- The Epson AcuLaser MX14 printer now works for the TS-563.
- Fixed an issue where the NAS would freeze due to some apps being unable to check for external resources (such as external IP addresses).
- Fixed an issue where users could get stuck attempting to log in to QTS due to an incorrect settings file.
- Fixed an issue where users cannot enable trusted domains in the Network Service after upgrading to QTS 4.2.0.
- Improved the stability of Download Station when using Magnet Links to download files on ARM-based NAS models.
[Applicable NAS]
All models except TVS-x71.
NAS
Network
Resources
Network
Resources
Same here. TS-453 Pro, running firmware TS-X53_20151023-4.2.0, with 8G RAM upgrade (also with 8G Curcial kit -- 2x CT51264BF160B), Active/Backup port trunking on ports 1+2. Additionally, on System Status applet, System Information, Network Status, and Hardware Information pages have no data. Even tried manual firmware update procedure (http://wiki.qnap.com/wiki/Manually_Updating_Firmware) to no avail.
Update: I replaced the Crucial memory with Kingston KVR16LS11/4 and the problems went away. Only been running in this configuration for 5 minutes, so I can't attest to its long-term effects, but definitely better!
- schumaku
QNAP kindly asks everyone with 3rd party memory showing these issues (being Dashboard, or System Status, or similar) to get in contact with the [url=htps://helpdesk.qnap.com/]QNAP customer service[/url] and be prepared for a remote access connection (ie. TeamViewer).
I was getting this issue on my TS-251 with the latest firmware (TS-X51_20151023-4.2.0) but it went away when I downgraded to
the previous version (TS-X51_20150925-4.2.0)
I have the same problem, blank resource monitor, completely blank system status, system information, network status, hardware information. I have the same Crucial 4G x 2 kit CT2KIT51264BF160B / CT2CP51264BF160B.
This is on my TS-451, with firmware 4.2.0 build 1023. Was working before I upgraded from 4.1.4 (not sure which build).
I'm in touch with QNAP support, I'll report back if there is any resolution.
Link for previous firmware for TS-251 and TS-451: http://us1.qnap.com/Storage/TS-X51/TS-X ... -4.2.0.zip
Looks like the newest firmware (4.2.0 build 1118) fixes the issue for me - Dashboard seems fine now
I upgraded from 1gb to 8gb and had the same issue with resource monitor, hardware tab, etc. The build 1118 resolved it.
This issue came back for me after upgrading my TS-231 to QTS 4.3.3.0174
As a result of this I got the same issue also in Qmanager 2.4.2 running iOS 10.3.1 on my mobile device
Is this an already known issue?
Any suggestions or workarounds for this very annoying bug?
Can verify that the CPU and Memory usage doesn't show up with firmware 4.3.3.0154 on my TS-831.
Looks like this app crashed hard with update 4.3.3.0154 on TVS-471. Unable to get it working again. Anyone else having a similar issue?
Same issue on TS453 Pro at 4.3.3.0154.
