usb dongle
usb dongle
I've hs-251+, yesterday I bougth Kinivo BTD-400 Bluetooth 4.0 USB Adapter to use with h2-251.
I've tried to install without success.
Can anyone help me?
thanks in advance
Can anyone help me?
thanks in advance
Re: usb dongle
what happened when you tried?
"without success" is very unspecific
Re: usb dongle
I've insert dongle in the usb port, the dongle led is turned on blue, and after nothing.
I've searched device with pc, iphone and mac, but doesn't found.
The usb port is ok, I tried it with keyboard; also the dongle I've tried with pc and work ok.
- Don
Re: usb dongle
I don't think qnap supports Bluetooth.
- schumaku
Re: usb dongle
What for you need a Bluetooth connection to the NAS when WiFi (and Ethernet) access does a much better job?capespingola wrote:I've searched device with pc, iphone and mac, but doesn't found.
These "generic" Bluetooth dingles are supported to connect Bluetooth speakers - from ie. Music Station or Qmusic.Don wrote:I don't think qnap supports Bluetooth.
Note: There is no USB Bluetooth HID emulation software on the NAS ot connct "generic" BT pointers and keyboards.capespingola wrote:The usb port is ok, I tried it with keyboard;
Re: usb dongle
thanks shumaku,
I need bluetooth to connect remote speaker or iphone, but the my qnap hs-251 doesn't see the bluetooth.
the hs251 doesn't have wifi or bluethooth integrate, both are usable with external usb peripherals.
I choose the usb model in the compatibility list from qnap site
https://www.qnap.com/i/au/product_x_gra ... I=197&hf=0
- schumaku
Re: usb dongle
Music Station ... click on the "headset" permitting to select the output ... no Bluetooth devices in sight?capespingola wrote:I need bluetooth to connect remote speaker
Again ... use the existing Wi-Fi. The supported Wi-Fi devices permit to connect to an existing WLAN as a client, it does not create an access point. For Bluetooth, there is no fully blown Bluetooth stack with HID emulation, networking over Bluetooth (an almost complete dead thing), ...capespingola wrote:or iphone
Re: usb dongle
in the headset menu there isn't usb deviceschumaku wrote:Music Station ... click on the "headset" permitting to select the output ... no Bluetooth devices in sight?capespingola wrote:I need bluetooth to connect remote speaker
the hs-251+ doesn't have integrated Wi-Fischumaku wrote:Again ... use the existing Wi-Fi. The supported Wi-Fi devices permit to connect to an existing WLAN as a client, it does not create an access point. For Bluetooth, there is no fully blown Bluetooth stack with HID emulation, networking over Bluetooth (an almost complete dead thing), ...
- schumaku
Re: usb dongle
What firmware/build number is in place on the HS-251+ ?capespingola wrote:in the headset menu there isn't usb device
Does it show up in the USB devices plugged, ie. like this:
[~] # lsusb
Bus 001 Device 002: ID 1c05:2074
Bus 001 Device 003: ID 2548:1002
Bus 001 Device 004: ID 1005:b155 Apacer Technology, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 003: ID 1c05:3074
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
[~] # lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 224 Wireless
bDeviceSubClass 1 Radio Frequency
bDeviceProtocol 1 Bluetooth
bMaxPacketSize0 64
idVendor 0x0a12 Cambridge Silicon Radio, Ltd
idProduct 0x0001 Bluetooth Dongle (HCI mode)
bcdDevice 88.91
iManufacturer 0
iProduct 2 CSR8510 A10
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 177
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 1 Bluetooth
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0009 1x 9 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0019 1x 25 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0021 1x 33 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0031 1x 49 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
Device Status: 0x0001
Self Powered
Yes - it has two perfectly performing Gigabit Ethernet interfaces. And you connect wiFi clients to the WLAN router or access points, ... not P2P to a NAS. Still can't see a need for this ...capespingola wrote:the hs-251+ doesn't have integrated Wi-Fi
Re: usb dongle
I'm having a similar issue. I want the bluetooth so I can play Music Station from the NAS and stream it to bluetooth so I can just turn on a wireless speaker in the house whenever I want to listen to music.
All of the ones listed as supported for TS-431+ appear to be Asian-based, and do not show up in Google Shopping, so I don't even know where to find them. Ended up getting an ASUS BT400 but QNAP isn't seeing it. I don't want it for networking, and I don't believe the OP wants it for networking either - we just want to be able to stream music from the NAS to a wireless bluetooth speaker.
Re: usb dongle
Same trouble here, stucking with the setup to get the bluetooth running...
if someone had any idea, please help.
Model: TS-251
Current firmware version: 4.2.1
[~] # lsusb
Bus 001 Device 003: ID 0a5c:21e8 Broadcom Corp.
Bus 002 Device 002: ID 1c05:3074
Bus 002 Device 003: ID 1058:0820 Western Digital Technologies, Inc.
[~] # lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 1
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x0a5c Broadcom Corp.
idProduct 0x21e8
bcdDevice 1.12
iManufacturer 1 Broadcom Corp
iProduct 2 BCM20702A0
iSerial 3 5CF3707444E5
bLength 9
bDescriptorType 2
wTotalLength 218
bNumInterfaces 4
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255 Vendor Specific Class
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
iInterface 0
Self Powered
Model: TS-251
[~] # lsusb
[~] # lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 1
bDeviceProtocol 1
bMaxPacketSize0 64
idProduct 0x21e8
bcdDevice 1.12
bLength 9
bDescriptorType 2
wTotalLength 218
bNumInterfaces 4
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 0
iInterface 0
Self Powered
- Don
Re: usb dongle
Open a ticket with QNAP.
- schumaku
Re: usb dongle
Read to me like the QNAP NAS have (just like ie. the RasPI) a problem recognizing the BCM20702 based BT 4.0 USB dongles (ASUS BT-400, most likely the Kinivo BTD-400, too) and fails to bring up HCI mode on it.
Get some dirt cheap Cambridge Silicon Radio BT dongles instead.
Some insight what can be done on a generic Linux system here - not applicable to the NAS (!!!) - https://urbanjack.wordpress.com/2014/02 ... us-bt-400/
