Tvs-682 Upgrade
Looma
First post
Tvs-682 Upgrade
Postby Looma » Thu Oct 27, 2016 5:25 pm
Hi Everybody,
I just bought unTVS-682 that I will receive it in a few days. I also bought an Intel CORE I7-6700T to replace the original processor and add 4x16 GB for a total of 64GB (HMA42GR7AFR4N).
I know that if I change the processor warranty will be void, but do this configuration work?
I took care to respect the TDP and the CPU socket : http://ark.intel.com/products/88200/Int ... o-3_60-GHz
Thank you in advance for your answers and advices.
jalokin
Re: Tvs-682 Upgrade
Postby jalokin » Sat Dec 10, 2016 6:24 pm
Did you manage to get this configuration to work? Was it possible to upgrade the CPU to an i7 and was the RAM compatible?
I am considering the same configuration if it works. Has anyone tried 2400 MhZ pc-19200 (CT4K16G4DFD824A)
kingking306
Re: Tvs-682 Upgrade
Postby kingking306 » Fri Dec 23, 2016 3:19 am
how's the i7 upgrade? is it hot?
Rowdyer
First post
Re: Tvs-682 Upgrade
Postby Rowdyer » Mon Dec 26, 2016 11:53 pm
Thinking about this aswell, how is it performing?
flyboyusa
Re: Tvs-682 Upgrade
Postby flyboyusa » Thu Jan 19, 2017 11:07 am
Is there any update from the OP on this? I'm wanting to upgrade to i7 but not sure if it's possible?
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Fri Jan 20, 2017 8:30 pm
Just ordered, anyone tried the CPU upgrade?
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Thu Jan 26, 2017 12:02 pm
Upgraded NAS to an i7 today, so far so good. Very easy upgrade and the system sees the 4/8 cores.
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Sat Jan 28, 2017 11:27 am
Well so far after 2 days and varied load the system is running fine.
Fans do seem a bit active at times but temperatures are all well within specs.
goldmanp
Re: Tvs-682 Upgrade
Postby goldmanp » Tue Jan 31, 2017 3:07 am
Hi, what TDP have you used for the TVS-68s CPU upgrade?
Thanks!
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Tue Jan 31, 2017 9:38 am
goldmanp wrote:Hi, what TDP have you used for the TVS-68s CPU upgrade?
Thanks!
I used a 65 watt, i7-6700 8M, BX80662I76700.
I am still using the stock Qnap passive CPU heat sink and so far so good.
I have been pusing it fairly hard, she has 6 windows VMs rung plus PLEX,and so far so good.
I have ordered second fan to go into the fan bracket over the m2 drives.
So,far heat on the CPU doesn't seem high, but the m2 drives seem a bit hot.
goldmanp
Re: Tvs-682 Upgrade
Postby goldmanp » Wed Feb 01, 2017 2:33 am
Thanks!
Thanks a lot for the info. I have seen the following approach and I thougth twice about cutting the case.
http://magcb.myqnapcloud.com/WordPress/ ... 2/?lang=en
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Wed Feb 01, 2017 7:22 am
goldmanp wrote:
Thanks!
The cooler looks good, I am going to order one.
I did not need to cut, modify or make any changes to the case, Qnap hardware on my NAS, I could change it back to factory in just a bit.
goldmanp
Re: Tvs-682 Upgrade
Postby goldmanp » Thu Feb 02, 2017 8:40 pm
Thanks alot for your help. Highly appreciated!
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Sun Feb 05, 2017 8:16 am
goldmanp wrote:Thanks alot for your help. Highly appreciated!
I switched to the cooler today for the one listed. Tight fit but I did not modify the case at all.
Watching the tempature now to see how she does.
Cbrad01
Re: Tvs-682 Upgrade
Postby Cbrad01 » Tue Feb 07, 2017 11:17 am
Well done with the upgrades for now
TVS-682 with i7 6700, 64 GB of Kingston ram, 4 4tb Hitachi drives raid 5, 1 Samsung 2tb SSD for vms , 1 Samsung 1tb SSD for system volume and 2 crucial 512 mb M.2 drives for caching the raid drives.
Using a corsair hydro cooler for the cpu.
Running 6 VMs, and a couple of plex streams, running at 75% or higher and temp is sittin at ~135 all day and stable. CPU fan sits at 800 to 1000 rpm...
Who is online
Users browsing this forum: Toxic17 and 7 guests
